[mapserver-users] changing opacity of a layer for a single client using map server
Sowmya Tiramdasu
stiramdasu at qcoherent.com
Thu Aug 2 14:58:27 PDT 2012
Thank you very much Steve for clarifying me question.
-Sowmya.
_______________________________
Sowmya Tiramdasu
QCoherent Software
9668 Madison Blvd., Suite 202
Madison, AL 35758
(256) 461-8289 Telephone
(256) 461-8249 Fax
www.geocue.com <http://www.geocue.com/>
From: Lime, Steve D (DNR) [mailto:Steve.Lime at state.mn.us]
Sent: Thursday, August 02, 2012 4:45 PM
To: Sowmya Tiramdasu; 'Mapserver-users'
Subject: RE: [mapserver-users] changing opacity of a layer for a single
The mapfile is loaded into memory and then MapScript acts upon those
structures. The original is unchanged.
Steve
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Sowmya
Tiramdasu
Sent: Thursday, August 02, 2012 4:10 PM
To: 'Mapserver-users'
Subject: [mapserver-users] changing opacity of a layer for a single client
using map server
Hi All,
I have a question relating to opacity of a layer. My requirement is to
change the opacity of a layer for a particular client. I thought, I can
achieve this using map script. But, one thing which is not clear to me is :
If I change the opacity of a layer through the map script , will the changes
get reflected back in to the map file and then to any other clients
accessing that map file?
If I make changes to the existing map object using mapscript , will those
changes be reflected back on to the map file? Please someone clarify me this
point.
Thanks in advance!
-Sowmya.
Sowmya Tiramdasu
QCoherent Software
Madison, AL 35758
(256) 461-8249 Fax
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120802/cb215f2f/attachment.html>
