[mapserver-users] getShape failing; changes from mapserver 5.6 to 6.0
Stefan Schwarzer
stefan.schwarzer at unep.org
Fri Aug 3 04:36:41 PDT 2012
Hi there,
I am struggling with a few changes I need to go through in order to make my code working now with mapserver 6.x. This one concerns the query part, when a user clicks on the map and a window with some metadata is being displayed.
An error message occurred:
"Catchable fatal error: Argument 1 passed to layerObj::getShape() must be an instance of resultObj, integer given"
When I changed the getShape command as indicated here [1], it says:
"Fatal error: Call to a member function getShape() on a non-object"
This is the code:
//Query the Map at the point clicked
if (!$imgbox)
@$a = $map -> queryByPoint($click_pt, MS_MULTIPLE, -1);
else
$a = $map -> queryByRect($click_rt);
if ($a == MS_SUCCESS)
$numResults = $Layer -> getNumResults();
$oLayer = $map -> getLayer($Layer -> index);
// Open layer's table... take the list of fields to display from
// the "HEADERRESULT_FIELDS" metadata in the layer object.
$oLayer -> open();
$oRes = $oLayer -> getResult(0);
//$oShape = $oLayer -> getShape($oRes->tileindex,$oRes->shapeindex); // before
$oShape = $layer -> getShape($oLayer -> getResult(0)); // now ??
while(list($key, $val) = each($oShape -> values))
//echo "<br />x - ".count($selFields)." - ".$key . " = " . $val;
if (($key <> "META_DATA") AND ($key <> "oid") AND ($key <> "id") AND ($key <> "uid"))
$selFields[count($selFields)] = $key;
Not sure what I should put there…
Thanks for any hints,
Stefan
[1] http://mapserver.org/MIGRATION_GUIDE.html
