[mapserver-users] MapServer configure question with PHP/MapScript Module
Jerome Villeneuve Larouche
jlarouche at mapgears.com
Tue Aug 7 07:39:09 PDT 2012
Hello,
I'm pretty sure that you could just write --with-php without any
arguments and it would work.
On 12-08-07 10:36 AM, ?? wrote:
> Hi, Everyone.
> I want to compile mapserver from source.
> Both the mapserver readme.configure file and the instuctionpost here
> (http://www.mapserver.org/installation/php.html) tell me
> "pass the /--with-php=DIR/ argument to the configure script",
> As the guide say, the "DIR" will be PHP sourcecode folder, but in my
> ubuntu 12.04 platform, it take aPHP5, no need to compile PHP from
> source. So I am confused, which folder should I assign?
> by the way, I "locate php5" on the shell and got the result below:
> /etc/php5
> /etc/apache2/mods-available/php5.conf
> /etc/apache2/mods-available/php5.load
> /etc/apache2/mods-enabled/php5.conf
> /etc/apache2/mods-enabled/php5.load
> /etc/apparmor.d/abstractions/php5
> /etc/cron.d/php5
> /etc/php5/apache2
> /etc/php5/cli
> /etc/php5/conf.d
> /etc/php5/apache2/conf.d
> /etc/php5/apache2/php.ini
> /etc/php5/cli/conf.d
> /etc/php5/cli/php.ini
> /etc/php5/conf.d/curl.ini
> /etc/php5/conf.d/mysql.ini
> /etc/php5/conf.d/mysqli.ini
> /etc/php5/conf.d/pdo.ini
> /etc/php5/conf.d/pdo_mysql.ini
> /usr/bin/php5
> /usr/lib/php5
> /usr/lib/apache2/modules/libphp5.so
> /usr/lib/php5/20090626
> /usr/lib/php5/libexec
> /usr/lib/php5/maxlifetime
> /usr/lib/php5/20090626/curl.so
> /usr/lib/php5/20090626/mysql.so
> /usr/lib/php5/20090626/mysqli.so
> /usr/lib/php5/20090626/pdo.so
> /usr/lib/php5/20090626/pdo_mysql.so
> /usr/share/php5
> /usr/share/apport/package-hooks/source_php5.py
> /usr/share/doc/libapache2-mod-php5
> /usr/share/doc/php5-cli
> /usr/share/doc/php5-common
> /usr/share/doc/php5-curl
> /usr/share/doc/php5-mysql
> /usr/share/doc/php5-common/CODING_STANDARDS.gz
> /usr/share/doc/php5-common/CREDITS
> /usr/share/doc/php5-common/EXTENSIONS.gz
> /usr/share/doc/php5-common/NEWS.Debian.gz
> /usr/share/doc/php5-common/README.Debian.gz
> /usr/share/doc/php5-common/README.Debian.security
> /usr/share/doc/php5-common/README.EXT_SKEL.gz
> /usr/share/doc/php5-common/README.PHP4-TO-PHP5-THIN-CHANGES.gz
> /usr/share/doc/php5-common/README.SELF-CONTAINED-EXTENSIONS.gz
> /usr/share/doc/php5-common/README.SVN-RULES.gz
> /usr/share/doc/php5-common/README.Zeus.gz
> /usr/share/doc/php5-common/TODO.gz
> /usr/share/doc/php5-common/changelog.Debian.gz
> /usr/share/doc/php5-common/copyright
> /usr/share/doc/php5-common/examples
> /usr/share/doc/php5-common/test-results.txt.gz
> /usr/share/doc/php5-common/examples/php.ini-development
> /usr/share/lintian/overrides/libapache2-mod-php5
> /usr/share/lintian/overrides/php5-cli
> /usr/share/lintian/overrides/php5-common
> /usr/share/man/man1/php5.1.gz
> /usr/share/php5/php.ini-production
> /usr/share/php5/php.ini-production-dist
> /usr/share/php5/php.ini-production.cli
> /var/cache/apt/archives/libapache2-mod-php5_5.3.10-1ubuntu3.2_amd64.deb
> /var/cache/apt/archives/php5-cli_5.3.10-1ubuntu3.2_amd64.deb
> /var/cache/apt/archives/php5-common_5.3.10-1ubuntu3.2_amd64.deb
> /var/cache/apt/archives/php5-curl_5.3.10-1ubuntu3.2_amd64.deb
> /var/cache/apt/archives/php5-mysql_5.3.10-1ubuntu3.2_amd64.deb
> /var/lib/php5
> /var/lib/dpkg/info/libapache2-mod-php5.conffiles
> /var/lib/dpkg/info/libapache2-mod-php5.list
> /var/lib/dpkg/info/libapache2-mod-php5.md5sums
> /var/lib/dpkg/info/libapache2-mod-php5.postinst
> /var/lib/dpkg/info/libapache2-mod-php5.postrm
> /var/lib/dpkg/info/libapache2-mod-php5.prerm
> /var/lib/dpkg/info/libapache2-mod-php5.triggers
> /var/lib/dpkg/info/php5-cli.list
> /var/lib/dpkg/info/php5-cli.md5sums
> /var/lib/dpkg/info/php5-cli.postinst
> /var/lib/dpkg/info/php5-cli.postrm
> /var/lib/dpkg/info/php5-cli.prerm
> /var/lib/dpkg/info/php5-common.conffiles
> /var/lib/dpkg/info/php5-common.list
> /var/lib/dpkg/info/php5-common.md5sums
> /var/lib/dpkg/info/php5-common.postrm
> /var/lib/dpkg/info/php5-curl.conffiles
> /var/lib/dpkg/info/php5-curl.list
> /var/lib/dpkg/info/php5-curl.md5sums
> /var/lib/dpkg/info/php5-mysql.conffiles
> /var/lib/dpkg/info/php5-mysql.list
> /var/lib/dpkg/info/php5-mysql.md5sums
> Best Regards,
> Yang Li
> GIS Developer
> P.R.China
> mapserver-users at lists.osgeo.org
Mapgears
www.mapgears.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120807/d32c41ff/attachment.html>
