[mapserver-users] label all parts of a multi-part polygon
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Aug 7 10:01:58 PDT 2012
On 8/7/2012 12:13 PM, Mark Volz wrote:
> Hello
> Is it possible to label all parts of a multi-part polygon? Please
> see geomoose.lyonco.org/geomoose2/ArcMapLabel.jpg for an example of
> what I would like to do.
Mark,
I don't think you can do this directly, you might want to open a new
ticket to add this as an enhancement. It should be triggered by some
optional tag in the label block so it can be turned on.
One work-around if you are using PostGIS is:
DATA "the_geom from (select gid, attr1, attr2, etc
(st_dump(the_geom)).geom as the_geom from mytable) using unique gid"
This has a problem in that gid will not be unique so you may will have a
problem if you use this in a query instead of a draw. Otherwise you may
need to modify the SQL to generate a unique id maybe doing some thing
like gid*100+path where path is the count of which geom in the
multipolygon geom represents.
-Steve
