[mapserver-users] transitioning between mapservers - port forwarding
Langlois, Dominique
Dominique.Langlois at RNCan-NRCan.gc.ca
Wed Aug 8 10:16:45 PDT 2012
We are currently serving many WMS and WFS services through a single IP address. To do so, we use Apache mod_rewrite module which permit to set some redirection based on rules in the configuration file. Google for 'Apache mod_rewrite' to find how to set rules.
Regards.
Dominique Langlois
Ressources naturelles Canada Natural Resources Canada
Centre d'information topographique Centre for Topographic Information
Sherbrooke, Canada
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mark Volz
Sent: August 8, 2012 12:28
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] transitioning between mapservers - port forwarding
Hello,
I would like to see if I can run both MS4W 3.0 beta 7 (mapserver 5) and MS4W 3.x (mapserver 6).
Background:
Currently I am using an older version of MS4W to host our GeoMOOSE 2.2 applications, which are not compatible with the newer versions of MS4W. In addition to using the older MS4W application, I would also like to add a new version of MS4W. This way I can transition to GeoMOOSE 2.6 (which runs on the newer MS4W distribution), and take advantage of MapCache without having to completely change all the applications at once. The server I have has two partitions and by renaming the service in Apache-install.bat I can run both both the old MS4W applications and the new MS4W applications.
Questions:
Has anyone else done anything similar to this?
Is there a way to only use one IP address or port? For example could I make: http://mysite/myOldApp go to the old version of MS4W and http://mysite/myNewApp go to the new version of MS4W?
Thanks for any ideas
Mark Volz
GIS Specialist
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
