[mapserver-users] Reading a custom GDAL raster format via MapServer...
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Thu Aug 9 08:00:31 PDT 2012
Is MapServer using the same GDAL as the commandline GDAL that can successfully open the file?
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Shri I
Sent: Thursday, August 09, 2012 9:49 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Reading a custom GDAL raster format via MapServer...
Hello All,
I have been trying to read a custom GDAL raster format via MapServer. (Unfortunately, I'm unable to share the file itself here, as it is a proprietary format). MapServer is unable to read the raster and display it. However, GDAL is able to read (gdalinfo, etc), translate (gdal_translate), transform (gdalwarp) the raster. Any ideas how to solve this? MapServer is compiled with GDAL support and everything looks OK. The "gdalinfo --formats " command shows the format is supported.
Here are the errors in my log:
msDrawMap(): rendering using outputformat named png (AGG/PNG).
msDrawMap(): WMS/WFS set-up and query, 0.000s
msDrawRasterLayerLow(testLayer): entering.
msDrawRasterLayerLow(): Unable to access file. Corrupt, empty or missing file '/path/to/myfile.ext' for layer 'testLayer'.
Image handling error. Failed to draw layer named 'testLayer'.
msFreeMap(): freeing map at 0xf8b8f0.
And here's the MapServer error included in the image or shown on the command prompt (when ran using mapserv command):
msDrawMap(): Image handling error. Failed to draw layer named 'testLayer'.
GDAL: GDALDeregister_GTiff() called.
Here's how my layer definition looks like:
LAYER
NAME "testLayer"
TYPE RASTER
DATA "/path/to/myfile.ext" # <<-- Tested with realtive path from shapepath and also direct path, as in this case.
STATUS ON
END
Thank you for your helpful pointers.
Regards,
Shri.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120809/d4570b6b/attachment-0001.html>
