[mapserver-users] KML generation-partially working
Sowmya Tiramdasu
stiramdasu at qcoherent.com
Wed Aug 15 03:48:30 PDT 2012
Hi Michael,
I see your point. But, the images itself are blank. So making the paths
absolute has no difference. When the output format is png, I get all the
layers rendered correctly. But when the Output format is set to KML only,
the image outputs from each layer are coming blank :(.
So any inputs regarding this? Has anyone else ran in to the same situation?
Thanks,
Sowmya.
_______________________________
Sowmya Tiramdasu
QCoherent Software
9668 Madison Blvd., Suite 202
Madison, AL 35758
(256) 461-8289 Telephone
(256) 461-8249 Fax
www.geocue.com <http://www.geocue.com/>
From: Smith, Michael ERDC-RDE-CRREL-NH [mailto:Michael.Smith at erdc.dren.mil]
Sent: Tuesday, August 14, 2012 4:26 PM
To: Sowmya Tiramdasu; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] KML generation-partially working
You probably have to set your WEB / IMAGEURL to an absolute path since
otherwise the kml references are relative and not picked up.
And please, reply to the list, there are others that can learn and respond
that way.
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
From: Sowmya Tiramdasu <stiramdasu at qcoherent.com>
Date: Tuesday, August 14, 2012 3:26 PM
To: Michael Smith <michael.smith at erdc.dren.mil>
Subject: RE: [mapserver-users] KML generation-partially working
Hi Michael,
I looked in to the KML file. It looks fine. But the Images which have been
generated in the ms_tmp files are blank. There was an image for each layer,
which came out to be blank and for my layer 'ControlPoints' I gave under
class ->Symbol-> Circle. So I have an image corresponding to this symbol in
ms_tmp which is being used as the styleUrl in the KML. yet I am seeing a
cross mark for that place mark in the Google earth.
For the layer 'sbet' - it is a line, so there is no image generated at all
and this layer is being displayed good on the Google earth.
LAYER
NAME ControlPoints #Photogrammetric
points
DATA Photogrammetric_Point
STATUS OFF
TYPE POINT
CLASS
STYLE
# Symbol to
be used (reference)
SYMBOL
"circle"
# Size of
the symbol in pixels
SIZE 8
COLOR 190 20
190
# Outline
colour (RGB) - black
OUTLINECOLOR
0 0 0
END
END
PROJECTION
"init=epsg:2246"
END
END
KML :
<Style id="style_symbol_circle_8.0_ffbe14be">
<IconStyle>
<Icon>
<href>/ms_tmp/502a9927_2bc4_10.png</href>
</Icon>
</IconStyle>
</Style>
<Folder>
<name>ControlPoints</name>
<visibility>1</visibility>
<styleUrl>#LayerFolder_check</styleUrl>
<Placemark>
<name>ControlPoints.0</name>
<styleUrl>#style_symbol_circle_8.0_ffbe14be</styleUrl>
<Point>
<coordinates>
-84.61444330,38.04278949
</coordinates>
</Point>
</Placemark>
-Thanks,
Sowmya.
Sowmya Tiramdasu
QCoherent Software
Madison, AL 35758
(256) 461-8249 Fax
Sent: Tuesday, August 14, 2012 10:37 AM
Have you looked inside the KML file?
You can also set a DEBUG value on your layer (and mapfile) and look for
anything that might be interrupting your KML write.
Mike
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120815/e81bf311/attachment-0001.html>
