[mapserver-users] GetCoverage with WCS 2.0.0: Unknown parameter time
Jonas Eberle
jonas.eberle at gmx.de
Sun Aug 19 02:55:08 PDT 2012
Hi Stephan,
thanks for the hint. I updated to MapServer 6.0.3 and this error disappeared.
Thanks,
Jonas
----- Ursprüngliche Mail -----
> Hi Jonas,
> sorry for my late reply. Could you please try with MapServer 6.0.3
> and
> report back? I suspect it's related to #4307 [1].
> cu
> Stephan
> [1] https://github.com/mapserver/mapserver/issues/4307
> On Tue, 2012-07-17 at 12:06 -0500, Jonas Eberle wrote:
> > Hi Stephan,
> > I am using Mapserver 6.0.1.
> > At the bottom the two layers, within the WEB section I have the the
> > validation block for parameter time.
> > This was the request with WCS 2.0.0:
> > http://artemis.geogr.uni-jena.de/cgi-bin/mapserv?map=/home/mapserver/modis/map.map&SERVICE=WCS&REQUEST=GetCoverage&VERSION=2.0.0&coverageID=NDVIData&format=GTiff&time=2012-04-01
> > The following request works with WCS 1.0.0:
> > http://artemis.geogr.uni-jena.de/cgi-bin/mapserv?map=/home/mapserver/modis/map.map&SERVICE=WCS&REQUEST=GetCoverage&VERSION=1.0.0&coverage=NDVIData&format=GTiff&time=2012-04-01&CRS=EPSG:4326&RESX=0.05&RESY=0.05
> > Thanks,
> > Jonas
> > WEB
> > VALIDATION
> > 'time' '^[0-9\-]+$'
> > END
> > END
> > LAYER
> > NAME 'time_idx_test'
> > TYPE POLYGON
> > CONNECTIONTYPE POSTGIS
> > CONNECTION "host=localhost dbname=** user=**
> > password=****** port=5432"
> > DATA "geom from mod13c2_ndvi"
> > METADATA
> > "ows_title" "MOD13C2_NDVI TIME INDEX"
> > "ows_srs" "EPSG:900913 EPSG:4326"
> > "ows_extent" "49 85 180 44"
> > "ows_timeextent" "2000-02-01/2012-05-01/P1M"
> > "ows_timeitem" "date"
> > "ows_timedefault" "2012-05-01"
> > "ows_enable_request" "*"
> > END
> > FILTERITEM 'date'
> > FILTER '%time%'
> > END
> > LAYER
> > NAME 'NDVIData'
> > STATUS ON
> > DEBUG 5
> > TYPE RASTER
> > TILEITEM 'location'
> > TILEINDEX 'time_idx_test'
> > PROJECTION
> > "init=epsg:4326"
> > END
> > METADATA
> > "wcs_label" 'NDVI data'
> > "ows_extent" "49 44 180 85"
> > "wcs_size" "7200 3599"
> > "wcs_bandcount" "1"
> > "ows_srs" 'EPSG:4326'
> > "wcs_rangeset_axes" 'bands'
> > "wcs_rangeset_name" 'bands'
> > "wcs_timeposition"
> > "2000-02-01,2000-03-01,2000-04-01,2012-04-01"
> > "wcs_timeitem" 'date'
> > "wcs_enable_request" "*"
> > END
> > END
> > > Hi Jonas,
> > > which version of MapServer are you using? I guess variable
> > > substitution
> > > should also be available in WCS 2.0. Could you send a short
> > > Mapfile
> > > and
> > > request to reproduce the behavior?
> > > cu
> > > Stephan
> > > On Tue, 2012-07-17 at 11:51 -0500, Jonas Eberle wrote:
> > > > Hi list,
> > > > I tried to use WCS 2.0.0 with Mapserver. Having time series
> > > > layers
> > > > with a tile index layer, I used variable substitution for the
> > > > different times. This works fine for WCS 1.0.0.
> > > > Trying the GetCoverage request with WCS 2.0.0 I get the
> > > > following
> > > > error message right after executing the request:
> > > > msWCSParseRequest20(): WCS server error. Unknown parameter:
> > > > 'time'.
> > > > Is there an other possibility to use variable substitution with
> > > > GetCoverage request in WCS 2.0.0?
> > > > Thanks,
> > > > Jonas
> > > > _______________________________________________
> > > > mapserver-users mailing list
> > > > mapserver-users at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
