[mapserver-users] oraclespatial connection
Michele De Santis
tape2m at virgilio.it
Mon Aug 20 08:37:33 PDT 2012
I'm using MS4W with connection to Oraclespatial. I followed the istructions on
http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#oracle-10g-11g
to enable Oracle 10g support and "mapserv -v" returns a string that contains
"INPUT=ORACLESPATIAL"
In mapfile I have a Layer:
LAYER
NAME PSITDATA.COMUNI
TYPE POLYGON
CONNECTIONTYPE oraclespatial
CONNECTION "UN/PW at DBSVILPU"
DATA "SHAPE FROM PSITDATA.COMUNI USING SRID 32633 VERSION 10g"
CLASS
STYLE
OUTLINECOLOR 0 0 0
COLOR 0 128 128
END
END
METADATA
"wms_title" "PSITDATA.COMUNI"
#"wms_srs" "EPSG:26591"
"wms_srs" "EPSG:32633"
"wms_name" "PSITDATA.COMUNI"
"wms_server_version" "1.1.1"
"wms_format" "image/png"
"wms_enable_request" "*" ##necessary
END
PROJECTION
"init=epsg:32633"
END
END
but I have the error:
ORA-06553: PLS-306: wrong number or types of arguments in call to 'SDO_FILTER'
Query statement: SELECT OBJECTID_1,rownum, SHAPE FROM PSITDATA.COMUNI
WHERE SDO_FILTER( SHAPE, MDSYS.SDO_GEOMETRY(2003, :srid,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates
),'querytype=window') = 'TRUE' . Check your data statement.
When I tried the SELECT in SQL*PLUS I had obtained:
SP2-0552: Bind variable "ORDINATES" not declared
Can you help me with the this error and with mapfile syntax?
Thank you
Michele
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120820/07d87a0e/attachment.html>
