[mapserver-users] Passing an additional parameter via URL for WMS request - doesn't work anymore with new mapserver?
Till Adams
adams at terrestris.de
Tue Aug 21 08:19:55 PDT 2012
Stefan,
this is a working example from a layer:
METADATA
'LEVEL_validation_pattern' '1|1,2|1,2,3|1,2,3,4|1,2,3,4,5'
'default_LEVEL' '1,2'
This sets the Keyword LEVEL which is added to your URL to the
Default-Value "1,2" and allows the values defined in the validation
pattern "LEVEL_validation_pattern"
Regards, Till
On 21.08.2012 16:41, Stefan Schwarzer wrote:
> Thanks so much for the quick responses!
> If I understand it correctly, I need to specify "DATAPATTERN" in the MAP part, in order to use the parameter in the DATA request:
> Doc is saying: LAYER: DATA (must validate against DATAPATTERN)
> which would look like this:
> SHAPEPATH '/www/xxx/data'
> FONTSET '/www/xxx/htdocs/mod_map/etc/fonts.txt'
> SYMBOLSET '/www/xxx/htdocs/mod_map/etc/symbols.sym'
> DATAPATTERN '^[0-9]'
> with the DATA request like:
> DATA "the_geom FROM (SELECT xxx FROM capitals WHERE capitals.id_country <> %id_country%) AS foo USING UNIQUE gid USING srid=4326"
> Hmmm…. But that doesn't work.
> msDrawMap(): Image handling error. Failed to draw layer named 'capitals_mask'.
> msPostGISLayerWhichShapes(): Query error. Error executing query: ERROR: syntax error at or near ")"
> LINE 1: ...capitals WHERE capitals.id_country <> %id_country%) AS foo w…
> Can you shed some light on it? I am not really familiar with the regular expressions. I am just passing an integer.
> Thanks for any hints!
> Stef
> On Aug 21, 2012, at 4:10 PM, Till Adams wrote:
>> Stefan,
>> from mapserver 6 on you must define the default values for the
>> parameters in your metadata-tag and also provide a validation-pattern.
>> You'll find more here:
>> http://mapserver.org/cgi/runsub.html
>> Regards, Till
>> On 21.08.2012 16:07, Stefan Schwarzer wrote:
>>> Hi there,
>>> I used to pass a parameter in a WMS request in order to specify which country should be highlighted. The MAPFILE would read that and, via an EXPRESSION, set all country but the selected one to a bit of opacity:
>>> That doesn't work anymore after upgrading our machine. So, I am not 100% sure if this comes from mapserver, or if there is anything else involved. But it seems more like a mapserver problem, as the error-message is
>>> <ServiceException>
>>> msDrawMap(): Image handling error. Failed to draw layer named 'capitals_selected'.
>>> msPostGISLayerWhichShapes(): Query error. Error executing query: ERROR: syntax error at or near "%"
>>> LINE 1: ...als.gid FROM capitals WHERE capitals.id_country = %id_countr...
>>> msValidateParameter(): Regular expression error. Parameter pattern validation failed.
>>> </ServiceException>
>>> Thanks for any hints/clarification.
>>> Stefan
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> NEWS:
>> -> GO Mobile - jetzt WebGIS auch auf Smartphones
>> -> Bald OpenSource! SHOGun - das JavaBackend für WebGIS Anwendungen
>> terrestris GmbH & Co. KG
>> Puetzchens Chaussee 56
>> 53227 Bonn
>> Germany
>> Till Adams
>> Geschaeftsfuehrung
>> Tel: +49 (0)228 / 962 899-52
>> Mobile: +49 (0)151 / 25394429
>> Fax: +49 (0)228 / 962 899-57
>> http://www.terrestris.de
>> Amtsgericht Bonn, HRA 6835
>> Komplementaerin:
>> terrestris Verwaltungs GmbH
>> vertreten durch:
>> Hinrich Paulsen, Till Adams
NEWS:
53227 Bonn
Germany
Till Adams
Geschaeftsfuehrung
Komplementaerin:
vertreten durch:
