[mapserver-users] validation block
thomas bonfort
thomas.bonfort at gmail.com
Tue Aug 21 08:52:37 PDT 2012
On Tue, Aug 21, 2012 at 5:38 PM, Marc-André Trottier
<marcandre_trottier at hotmail.com> wrote:
> there is my layer's definition :
> LAYER
> VALIDATION
> ID_BASSIN '[[a-zA-Z0-9]{0,10},??]*'
> #ID_REG '[[a-zA-Z0-9]{0,10},??]*'
> END
> INCLUDE "../layers/bd/adn_station_max_v.map"
> CLASSGROUP "BASSIN"
> NAME "adn_station_bassin"
> END
> LAYER
> VALIDATION
> #ID_BASSIN '[[a-zA-Z0-9]{0,10},??]*'
> END
> CLASSGROUP "REG_ADMIN"
> NAME "adn_station_reg_admin"
> END
> with these commented lines a got this error :
> msValidateParameter(): Regular expression error. Parameter pattern
> validation failed.
> without comment, i got no error.
> CLASSGROUP 'BASSIN' contains many class but each class use only 'ID_BASSIN'
> and
> CLASSGROUP 'REG_ADMIN' contains many class but each class use only 'ID_REG'
Are you certain of that? You are including the same file in both ...
> is it the right thing to do ? or like i thought, the validation block can
> contains only the variable used by the layer ?
> mapserver-users at lists.osgeo.org
