[mapserver-users] validation block
Marc-André Trottier
marcandre_trottier at hotmail.com
Tue Aug 21 10:33:38 PDT 2012
here is an example of two class in 'adn_station_max_v.map' :
CLASS
NAME "Information non disponible (grande échelle)"
EXPRESSION ( '[etat]' = 'GRIS' AND [id_bassin] in '%ID_BASSIN%')
GROUP "BASSIN"
MINSCALEDENOM 0
MAXSCALEDENOM 150000
STYLE
SYMBOL 'circle'
COLOR 128 128 128
OUTLINECOLOR 0 0 0
SIZE 9
END
LABEL
COLOR 0 0 0
OUTLINECOLOR 255 255 255
ANTIALIAS FALSE
TYPE TRUETYPE
FONT "ubuntu"
SIZE 14
POSITION auto
FORCE TRUE
END
END
CLASS
NAME "Seuil d\'inondation majeure"
EXPRESSION ( '[etat]' = 'ROUGE' AND [region_admin_id] in '%ID_REG%')
GROUP "REG_ADMIN"
MINSCALEDENOM 110000
STYLE
SYMBOL 'circle'
COLOR 255 0 0
OUTLINECOLOR 0 0 0
SIZE 14
END
LABEL
WRAP "!"
ALIGN CENTER
COLOR 0 0 0
ANTIALIAS FALSE
TYPE TRUETYPE
FONT "ubuntu"
SIZE 14
FORCE TRUE
OFFSET 0 12
END
END
if i understant this meant that for a layer, i must validate all variables
of all class even if i don't use them all.
My include of 'adn_station_max_v.map' contains X substitutions in X class
so i must have X validations even if i don't use all X class.
In my example, i include many class with 'adn_station_max_v.map' but i'm
using only one variable at a time. All class in CLASSGROUP 'REG_ADMIN' only
use 'ID_REG'.
2012/8/21 Stephen Woodbridge <woodbri at swoodbridge.com>
> You probably need to quote:
> 'ID_BASSIN' '[[a-zA-Z0-9]{0,10},??]*'
> "#ID_REG' '[[a-zA-Z0-9]{0,10},??]*'
> And I would be very suspicious that '#ID_REG' is a value identifier
> because of the '#' character.
> -Steve W
> On 8/21/2012 11:38 AM, Marc-André Trottier wrote:
>> there is my layer's definition :
>> LAYER
>> VALIDATION
>> ID_BASSIN '[[a-zA-Z0-9]{0,10},??]*'
>> #ID_REG '[[a-zA-Z0-9]{0,10},??]*'
>> END
>> INCLUDE "../layers/bd/adn_station_max_**v.map"
>> CLASSGROUP "BASSIN"
>> NAME "adn_station_bassin"
>> END
>> LAYER
>> VALIDATION
>> #ID_BASSIN '[[a-zA-Z0-9]{0,10},??]*'
>> END
>> CLASSGROUP "REG_ADMIN"
>> NAME "adn_station_reg_admin"
>> END
>> with these commented lines a got this error :
>> msValidateParameter(): Regular expression error. Parameter pattern
>> validation failed.
>> without comment, i got no error.
>> CLASSGROUP 'BASSIN' contains many class but each class use only
>> 'ID_BASSIN' and
>> CLASSGROUP 'REG_ADMIN' contains many class but each class use only
>> 'ID_REG'
>> is it the right thing to do ? or like i thought, the validation block
>> can contains only the variable used by the layer ?
>> ______________________________**_________________
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.**org <mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/**mailman/listinfo/mapserver-**users<http://lists.osgeo.org/mailman/listinfo/mapserver-users>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120821/229bcce1/attachment.html>
