[mapserver-users] validation block
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Tue Aug 21 12:28:35 PDT 2012
I do something like the second example in one of my applications. I send the comma-delimited string for use as part of the IN statement.
This basically allows you to symbolize features from your spatial data set based on data passed in through the URL.
I pass these URL vars:
&group1=129,119,041,005,159,051,011,147,097,015,067,171,081,063,025,093,009,149,079,049,065,003,143,027,039,007,099,121,151,135,107,047,033,031,023,089,001,013,161,109,139,061,055,101,045,127,113,117,167,085,133,073,071,157,105,083,165,077,111,059,115,019,153,125,169,087,043,145,017,131,021,173,035,095,091,155,057,103,075,029,069&group2=137,163,037,141,123&group3=&group4=053
Here is the layer definition:
LAYER
NAME "airdata"
STATUS DEFAULT
DATA 'county_thin'
TYPE POLYGON
TEMPLATE "templates/emiss_imap_template.html"
VALIDATION
group1 "^[0-9\,]+$"
group2 "^[0-9\,]+$"
group3 "^[0-9\,]+$"
group4 "^[0-9\,]+$"
END
CLASS
NAME "group1"
EXPRESSION ('[county_fip]' IN '%group1%')
STYLE
COLOR 241 238 246
END
END
CLASS
NAME "group2"
EXPRESSION ('[county_fip]' IN '%group2%')
STYLE
COLOR 189 201 225
END
END
CLASS
NAME "group3"
EXPRESSION ('[county_fip]' IN '%group3%')
STYLE
COLOR 116 169 207
END
END
CLASS
NAME "group4"
EXPRESSION ('[county_fip]' IN '%group4%')
STYLE
COLOR 5 112 176
END
END
END
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
Sent: Tuesday, August 21, 2012 1:16 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] validation block
Typically the SQL syntax is column in (a,b,c,d)
So based on this
[id_bassin] in '%ID_BASSIN%'
would be problematic I think because your syntax is:
column in 'string'
Which is not valid. Also what is your validation for %ID_BASSIN%?
Is something like this? ^\([0-9]+(,[0-9]+)*\)$
where ID_BASSIN=(123,234,345)
or do you want something like:
[id_bassin] in (%ID_BASSIN%)
with a valdiation like: ^[0-9]+(,[0-9]+)*$
where ID_BASSIN=123,234,345
-Steve W
On 8/21/2012 1:33 PM, Marc-André Trottier wrote:
> here is an example of two class in 'adn_station_max_v.map' :
> CLASS
> NAME "Information non disponible (grande échelle)"
> EXPRESSION ( '[etat]' = 'GRIS' AND [id_bassin] in '%ID_BASSIN%')
> GROUP "BASSIN"
> MINSCALEDENOM 0
> MAXSCALEDENOM 150000
> STYLE
> SYMBOL 'circle'
> COLOR 128 128 128
> OUTLINECOLOR 0 0 0
> SIZE 9
> END
> LABEL
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> ANTIALIAS FALSE
> TYPE TRUETYPE
> FONT "ubuntu"
> SIZE 14
> POSITION auto
> FORCE TRUE
> END
> END
> CLASS
> NAME "Seuil d\'inondation majeure"
> EXPRESSION ( '[etat]' = 'ROUGE' AND [region_admin_id] in '%ID_REG%')
> GROUP "REG_ADMIN"
> MINSCALEDENOM 110000
> STYLE
> SYMBOL 'circle'
> COLOR 255 0 0
> OUTLINECOLOR 0 0 0
> SIZE 14
> END
> LABEL
> WRAP "!"
> ALIGN CENTER
> COLOR 0 0 0
> ANTIALIAS FALSE
> TYPE TRUETYPE
> FONT "ubuntu"
> SIZE 14
> FORCE TRUE
> OFFSET 0 12
> END
> END
> if i understant this meant that for a layer, i must validate all
> variables of all class even if i don't use them all.
> My include of 'adn_station_max_v.map' contains X substitutions in X
> class so i must have X validations even if i don't use all X class.
> In my example, i include many class with 'adn_station_max_v.map' but
> i'm using only one variable at a time. All class in CLASSGROUP 'REG_ADMIN'
> only use 'ID_REG'.
> 2012/8/21 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>
> You probably need to quote:
> 'ID_BASSIN' '[[a-zA-Z0-9]{0,10},??]*'
> "#ID_REG' '[[a-zA-Z0-9]{0,10},??]*'
> And I would be very suspicious that '#ID_REG' is a value identifier
> because of the '#' character.
> -Steve W
> On 8/21/2012 11:38 AM, Marc-André Trottier wrote:
> there is my layer's definition :
> LAYER
> VALIDATION
> ID_BASSIN '[[a-zA-Z0-9]{0,10},??]*'
> #ID_REG '[[a-zA-Z0-9]{0,10},??]*'
> END
> INCLUDE "../layers/bd/adn_station_max___v.map"
> CLASSGROUP "BASSIN"
> NAME "adn_station_bassin"
> END
> LAYER
> VALIDATION
> #ID_BASSIN '[[a-zA-Z0-9]{0,10},??]*'
> END
> CLASSGROUP "REG_ADMIN"
> NAME "adn_station_reg_admin"
> END
> with these commented lines a got this error :
> msValidateParameter(): Regular expression error. Parameter pattern
> validation failed.
> without comment, i got no error.
> CLASSGROUP 'BASSIN' contains many class but each class use only
> 'ID_BASSIN' and
> CLASSGROUP 'REG_ADMIN' contains many class but each class use
> only 'ID_REG'
> is it the right thing to do ? or like i thought, the validation
> block
> can contains only the variable used by the layer ?
> _________________________________________________
> mapserver-users at lists.osgeo.__org
> <mailto:mapserver-users at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/mapserver-__users
> <http://lists.osgeo.org/mailman/listinfo/mapserver-users>
