[mapserver-users] Tile Index Issues
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Aug 22 06:03:25 PDT 2012
I have a feeling that I had problems with vector tile index and native Mapserver connection. For some reason I have changed our mapfiles to connect with OGR. Anyway, now when I had a try, both are working. Perhaps I had some issues with GetFeatureInfo and not with GetMaps. I have created my tileindex shapefiles with ogrtindex utility, and location records look a bit different
z:\Data\contours\KM18M1BV.SHP,0
My connection alternatives which both work now (MS 6.0) are
CONNECTIONTYPE OGR
TILEINDEX "z:/data/Tindex/korkeusidx.shp,0"
# TILEINDEX "z:/data/Tindex/korkeusidx" #both with or without .shp works here
# TILEITEM "location"
-Jukka Rahkonen-
Jeff McKenna wrote:
> Hello,
> You might also test your mapfile with the shp2img utility
> (http://mapserver.org/utilities/shp2img.html) with the switch "-all_debug 5"
> to see your errors (and report to this list).
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 12-08-21 8:38 PM, Peter Mallen wrote:
> > Hello All,
> > I am new to map server and I am attempting to display polygon shapefiles
> > using a tile index but have not been able to see any results.
> > Eventually I would like to use these tiles to place images(raster) files
> > on my map but I was first just testing the 'TILEINDEX' feature with
> > vector data.
> > All of the shapefiles being referenced in my index shapefile are in the
> > same folder.
> > Also, in my index shapefile I have the following two shapefiles
> > referenced under the 'location' column:
> > \ms4w\Apache\htdocs\map.data\Guatemala_Cities.shp
> > \ms4w\Apache\htdocs\map.data\Bolivian_Cities.shp
> > The following page was used as a reference for creating my map file:
> > http://mapserver.org/utilities/tile4ms.html
> > Any help on this would be great.
> > Thank You,
> > Peter Mallen
> mapserver-users at lists.osgeo.org
