[mapserver-users] Tile Index Issues (Stephen Woodbridge)
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Aug 22 19:38:17 PDT 2012
On 8/22/2012 6:01 PM, Peter Mallen wrote:
> Hi Stephen,
> I have posted part of my mapfile below. I am also using the debug to
> send any errors to the log but no errors seem to come up. Forgot to
> mention that my shapefiles display in QGIS when using the tile index
> shapefile.
I would try this:
LAYER
NAME 'banner1'
STATUS DEFAULT
DEBUG 5
# don't need OGR, but if you want to use it try this first
# sometimes \ can be a problem so trying /
# you do not need .shp on the tileindex or shapefile names
# but it should not matter either
TILEINDEX 'C:/ms4w/Apache/htdocs/map.data/tindex-3'
TYPE POLYGON
PROJECTION "init=epsg:4326" END
CLASS
STYLE
COLOR "#ffff00" # yellow polygons
OUTLINECOLOR "#222222" # with dark borders
END
END
END
Try this first, if it works then try changing things one at a time and
retest to make sure it continues to work. Then if you find something
that breaks it and you do not understand why ask.
-Steve W
> LAYER
> NAME 'banner1'
> STATUS DEFAULT
> DEBUG 5
> CONNECTIONTYPE OGR
> TILEINDEX 'C:\ms4w\Apache\htdocs\map.data\tindex-3.shp'
> TILEITEM 'location'
> TYPE POLYGON
> TRANSFORM OFF
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> "datum=WGS84"
> "epsg:4326"
> END
> END
> Thank you,
> Peter Mallen
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> mapserver-users-request at lists.osgeo.org
> Sent: Wednesday, August 22, 2012 9:51 AM
> To: mapserver-users at lists.osgeo.org
> Subject: mapserver-users Digest, Vol 55, Issue 45
> Send mapserver-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> mapserver-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific than
> "Re: Contents of mapserver-users digest..."
> Today's Topics:
> 1. Re: Tile Index Issues (Stephen Woodbridge)
> 2. Export map into pdf (sharad)
> 3. Re: Export map into pdf (Till Adams)
> 4. Re: Export map into pdf (Rahkonen Jukka)
> 5. Re: Tile Index Issues (Jeff McKenna)
> 6. Re: Tile Index Issues (Rahkonen Jukka)
> 7. mapserver user can not make the shapefile data correctly show
> in the browser (??)
> Message: 1
> Date: Tue, 21 Aug 2012 20:57:22 -0400
> From: Stephen Woodbridge <woodbri at swoodbridge.com>
> Subject: Re: [mapserver-users] Tile Index Issues
> Message-ID: <50342E72.1020205 at swoodbridge.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> On 8/21/2012 7:38 PM, Peter Mallen wrote:
>> Hello All,
>> I am new to map server and I am attempting to display polygon
>> shapefiles using a tile index but have not been able to see any
> results.
>> Eventually I would like to use these tiles to place images(raster)
>> files on my map but I was first just testing the 'TILEINDEX' feature
>> with vector data.
>> All of the shapefiles being referenced in my index shapefile are in
>> the same folder.
>> Also, in my index shapefile I have the following two shapefiles
>> referenced under the 'location' column:
>> \ms4w\Apache\htdocs\map.data\Guatemala_Cities.shp
>> \ms4w\Apache\htdocs\map.data\Bolivian_Cities.shp
>> The following page was used as a reference for creating my map file:
>> http://mapserver.org/utilities/tile4ms.html
>> Any help on this would be great.
>> Thank You,
>> Peter Mallen
> What does your mapfile look like?
> Message: 2
> Date: Wed, 22 Aug 2012 02:39:51 -0700 (PDT)
> From: sharad <fine_sharad at hotmail.com>
> Subject: [mapserver-users] Export map into pdf
> Message-ID: <1345628391878-4996952.post at n6.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> hi all,
> i am developing web application using mapserver with C#/Mapscript.
> how can I export map into pdf file using c#/mapscript?
> I will appreciate your reply.
> thanks
> sharad
> http://osgeo-org.1560.n6.nabble.com/Export-map-into-pdf-tp4996952.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> Message: 3
> Date: Wed, 22 Aug 2012 11:45:02 +0200
> From: Till Adams <adams at terrestris.de>
> Subject: Re: [mapserver-users] Export map into pdf
> Message-ID: <5034AA1E.1080806 at terrestris.de>
> Hi Sharad,
> we use MapFish-print-servlet, which is the best software I know for
> generating maps in pdf.
> -> http://www.mapfish.org/doc/print/
> But this is in Java, so the other side of the river ;-)
> Reagrds, Till
> On 22.08.2012 11:39, sharad wrote:
>> hi all,
>> thanks
>> sharad
