[mapserver-users] Remote PostGIS server connection problem
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Aug 23 06:20:03 PDT 2012
Hi Matej,
Are specifying a user name in your connection?
If not then psql uses you user as the use name, but the apache uses
whatever name is associated with the apache user.
Do you get an error if you run shp2img or if you run:
/path/to/mapserv QUERY_STRING='your mapserver request arguments'
-Steve
On 8/23/2012 9:02 AM, Matej Mailing wrote:
> Hi,
> I am running 6.0.1 on a FreeBSD host. Everything works perfect when I
> connect to the local PostGIS server (located on the same machine as
> the Mapserver is running on). When I try to connect to the PostGIS
> server that is not in the same network, I get the following error:
> "msDrawMap(): Image handling error. Failed to draw layer named
> 'LAYER_NAME'. msPostGISLayerOpen(): Query error. Database connection
> failed (could not connect to server: Permission denied Is the server
> running on host "IP" and accepting TCP/IP connections on port 5432? Is
> it allowing connections? Does the specified user exist? Is the
> password valid? Is the database on the standard port?
> 1. I can connect to the server IP on port 5432 via paql from console
> from the machine where Mapserver is running.
> 2. When doing tcpdump dst 5432 on the PostGIS server that is outside,
> I see no traffic comming in so basically when the error is displayed
> it is not due to remote server settings.
> I was browsing on the web and found out that people that were using
> SELinux had to enable the option httpd_can_network_connect. It seems
> like the Apache is not allowed to initiate a remote connection to a
> non-local IP address. Is it the Apache limitation? Is it the OS
> limitation or is it the Mapserver limitation (I am pretty sure that it
> isn't, but I don't know where to look anymore ...)
> After pulling my hair for several hours any help or idea would be very
> welcome :-)
> TIA,
> Matej
> mapserver-users at lists.osgeo.org
