[mapserver-users] postgis-topology-how to use topogeom field
csaba toth
akoel at yahoo.com
Thu Aug 23 17:26:48 PDT 2012
As I know the topogeom type is automatically casting to geometry type.
So I have a table (telek) with a field of topogeom (topo_geom) in the postgresql db (tdc)
I made a map file for the mapserver and the layer looks like this:
LAYER
NAME "telek"
CONNECTIONTYPE postgis
CONNECTION "host=localhost password=postgres user=postgres dbname=tdc"
DATA "topo_geom from public.telek"
STATUS DEFAULT
TYPE LINE
TOLERANCE 10
PROJECTION
"init=epsg:2370"
END
CLASS
STYLE
COLOR 0 0 255
WIDTH 10
END
END
END
But I got the following error message when I try to display the map:
msDrawMap(): Image handling error. Failed to draw layer named 'telek'.
msPostGISLayerWhichShapes(): Query error. Error executing query: ERROR:
find_srid() - couldnt find the corresponding SRID - is the geometry
registered in the GEOMETRY_COLUMNS table? Is there an
uppercase/lowercase missmatch?
What could be the problem?
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120823/1c51ea07/attachment.html>
