[mapserver-users] still have problem when add postgis layer on mapserver mapfile
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Sun Aug 26 14:22:49 PDT 2012
- This may be a typo:
NAME "places1"
DATA "geometry from osm_new_mainroads using unique osm_id using srid 3785"
TYPE POINT
Or do you really have your places are in osm_new_mainroads table.
- Then it is a good habit to have PROJECTION block in both the MAP block and for each LAYER.
- It is also a good habit to use DEBUG 5 and see what you get into the block
- shp2img is better for testing than a browser but mode=map is OK too. Remember to set layers to default (as you had) or give layer names with &layers= parameter
- Finally, I think it would be good to add STYLE into your layer, inside CLASS.
See the "Very basic WMS Server mapfile" example at the bottom of page http://mapserver.org/ogc/wms_server.html
It should be OK. Perhaps it could be even a bit more simple because now it has a reference to a symbolset file. A very, very basic mapfile should be made to work without external symbols.
-Jukka Rahkonen-
李杨 [gisyangli] wrote:
> I try to load a postgis data layer on my mapfile, have problem when configure the mapfile done, then visit it using "http://127.0.0.1/cgi-bin/mapserv?&map=/var/www/osm-google.map&mode=map&mode=map" on the browser address. , only a blank blue image return, with no expected dot info.
> I can not figure out which step is have problem.
> Provide background info:
ogrinfo for the database table:
jack at jack-Vostro-1450:/usr/lib/cgi-bin$ ogrinfo PG:"host=127.0.0.1 user=osm password=osm dbname=osm port=5432" osm_new_mainroads -summary
INFO: Open of `PG:host=127.0.0.1 user=osm password=osm dbname=osm port=5432'
using driver `PostgreSQL' successful.
Layer name: osm_new_mainroads
Geometry: Line String
Feature Count: 9704
Extent: (-9871463.421196, 3533052.471384) - (-9460289.228784, 4190971.740014)
Layer SRS WKT:
PROJCS["Popular Visualisation CRS / Mercator (deprecated)",
GEOGCS["Popular Visualisation CRS",
DATUM["Popular_Visualisation_Datum",
SPHEROID["Popular Visualisation Sphere",6378137,0,
AUTHORITY["EPSG","7059"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6055"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.01745329251994328,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4055"]],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
PROJECTION["Mercator_1SP"],
PARAMETER["central_meridian",0],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
AUTHORITY["EPSG","3785"],
AXIS["X",EAST],
AXIS["Y",NORTH]]
FID Column = id
Geometry Column = geometry
osm_id: Integer (0.0)
type: String (255.0)
tunnel: Integer (5.0)
bridge: Integer (5.0)
oneway: Integer (5.0)
ref: String (255.0)
z_order: Integer (5.0)
.map(uing in the link above : osg-google.map) info for configure:
MAP
NAME places1
STATUS ON
SIZE 800 800
EXTENT -9871463.421196 3533052.471384 -9460289.228784 4190971.740014
UNITS meters
IMAGECOLOR 153 179 204
WEB
IMAGEPATH "/var/www/output"
IMAGEURL "/output/"
END
LAYER
STATUS DEFAULT
NAME "places1"
TYPE POINT
CONNECTIONTYPE postgis
CONNECTION "host=localhost dbname=osm user=osm password=osm port=5432"
CLASS
NAME "places1_color"
COLOR 255 215 0
END
END
END
for a explanation , whenever set "DATA "geometry from osm_new_mainroads using unique osm_id using srid 3785"",
DATA "geometry from osm_new_mainroads", or
DATA "geometry from osm_new_mainroads using unique osm_id using srid 3875
is the same , a blank image return
massperv version info:
./mapserv -v
MapServer version 6.0.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I try to experiment it in two different laptop and can not get expected result.
Please those with experience help me., this problem qurrall me a lot this weeked.
Thanks a lot.
Yang Li
GIS Developer
P.R.China
