[mapserver-users] Mapserver doesn't work as WMS-Client. Debian version 6.0.1-3.1 (Debian wheezy).
Pablo Diaz
inspdr00 at gmail.com
Mon Aug 27 01:22:55 PDT 2012
I've a problem with mapserver as a cgi-bin in Debian Weezy (mapserver
version -> 6.0.1-3.1). When I try to connect with a external layer as WMS
layer I always have same response:
<ServiceExceptionReport xmlns="http://www.opengis.net/ogc" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance" version="1.3.0"
xsi:schemaLocation="http://www.opengis.net/ogc
http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd">
<ServiceException code="LayerNotDefined">
msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the
LAYERS parameter.
</ServiceException>
</ServiceExceptionReport>
My mapserver call is this:
http://localhost/cgi-bin/mapserv?map=/var/local/mapserver/PPGIS/map/client_draw.map&SRS=EPSG%3A23029&LAYERS=pnoa&TRANSPARENT=TRUE&FORMAT=image%2Fpng&VISIBLE=false&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&STYLES=&BBOX=591337.45949865,4782765.2220358,595521.36140145,4785376.1944042&WIDTH=1384&HEIGHT=864
And my layer definition in mapfile is this:
LAYER
NAME 'pnoa'
TYPE RASTER
STATUS OFF
#GROUP "Fondo"
CONNECTION "http://www.idee.es/wms/PNOA/PNOA?"
CONNECTIONTYPE WMS
METADATA
"wms_name" "pnoa"
"wms_srs" "EPSG:23029"
"wms_format" "image/png"
"wms_title" "PNOA"
"wms_server_version" "1.3.0"
"wms_exceptions_format" "application/vnd.ogc.se_xml"
LEGEND_META_LAYER "CHECKBOX"
BASE_LAYER '0'
LEGEND_ORDER "99"
QUERYABLE "0"
END
PROJECTION
"init=epsg:23029"
END
END
Any idea?
Thanks in advance.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120827/829b1030/attachment.html>
