[mapserver-users] Mapserver doesn't work as WMS-Client. Debian version 6.0.1-3.1 (Debian wheezy).
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Aug 27 02:11:21 PDT 2012
Works for me with MS4W and Mapserver 6.2 beta2 after changing
"wms_server_version" "1.3.0" into
"wms_server_version" "1.1.1"
I could not manage to get the invalid layers error and the too high version error was on plain understandable text. It would be easier to read the logs and responses if some part of "PNOA" and "pnoa" words were changed to something else where they can be changed.
-Jukka Rahkonen-
Pablo Diaz wrote:
I've a problem with mapserver as a cgi-bin in Debian Weezy (mapserver version -> 6.0.1-3.1). When I try to connect with a external layer as WMS layer I always have same response:
<ServiceExceptionReport xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd">
<ServiceException code="LayerNotDefined">
msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the LAYERS parameter.
</ServiceException>
</ServiceExceptionReport>
My mapserver call is this:
http://localhost/cgi-bin/mapserv?map=/var/local/mapserver/PPGIS/map/client_draw.map&SRS=EPSG%3A23029&LAYERS=pnoa&TRANSPARENT=TRUE&FORMAT=image%2Fpng&VISIBLE=false&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&STYLES=&BBOX=591337.45949865,4782765.2220358,595521.36140145,4785376.1944042&WIDTH=1384&HEIGHT=864
And my layer definition in mapfile is this:
LAYER
NAME 'pnoa'
TYPE RASTER
STATUS OFF
#GROUP "Fondo"
CONNECTION "http://www.idee.es/wms/PNOA/PNOA?"
CONNECTIONTYPE WMS
METADATA
"wms_name" "pnoa"
"wms_srs" "EPSG:23029"
"wms_format" "image/png"
"wms_title" "PNOA"
"wms_exceptions_format" "application/vnd.ogc.se_xml"
LEGEND_META_LAYER "CHECKBOX"
BASE_LAYER '0'
LEGEND_ORDER "99"
QUERYABLE "0"
END
PROJECTION
"init=epsg:23029"
END
END
Any idea?
Thanks in advance.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120827/1a0e6be4/attachment-0001.html>
