[mapserver-users] Error compiling Mapserver 6.0.3
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Thu Aug 30 03:05:51 PDT 2012
That's what I did on Debian Squeeze:
$ wget -O- "http://download.osgeo.org/mapserver/mapserver-6.0.3.tar.gz" | tar xz
$ cd mapserver-6.0.3/
$ ./configure --with-ogr=/usr/bin/gdal-config --with-gdal=/usr/bin/gdal-config --with-wfsclient --with-wmsclient --enable-debug --with-curl-config=/usr/bin/curl-config --with-proj=/usr --with-tiff --with-gd=/usr --with-jpeg --with-freetype=/usr/bin/freetype-config --with-threads --with-wcs --with-libiconv=/usr --with-geos=/usr/bin/geos-config --with-libiconv=/usr --with-xml2-config=/usr/bin/xml2-config --with-sos --with-postgis=/usr/bin/pg_config
MapServer is now configured for
-------------- Compiler Info -------------
C compiler: gcc -g -fPIC -Wall
C++ compiler: g++ -g -fPIC -Wall
Debug: -g
Generic NINT:
-------------- Renderer Settings ---------
OpenGL support:
zlib support: -DUSE_ZLIB
png support: -DUSE_PNG
gif support: -DUSE_GIF
jpeg support: -DUSE_JPEG
freetype support: -DUSE_FREETYPE
iconv support: -DUSE_ICONV
AGG support: internal
SVG Symbol support: -DUSE_AGG_SVG_SYMBOLS
Cairo (SVG,PDF) support:
KML support:
-------------- Support Libraries ---------
Proj.4 support: -DUSE_PROJ
Libxml2 support: -DUSE_LIBXML2
FriBidi support:
Curl support: -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH
FastCGI support:
Threading support: -DUSE_THREAD
GEOS support: -DUSE_GEOS
XML Mapfile support:
XSLT support:
EXSLT support:
-------------- Data Format Drivers -------
PostGIS support: -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION
ArcSDE support:
OGR support: -DUSE_OGR
GDAL support: -DUSE_GDAL
Oracle Spatial support:
-------------- OGC Services --------------
WMS Server: -DUSE_WMS_SVR
WMS Client: -DUSE_WMS_LYR
WFS Server:
WFS Client: -DUSE_WFS_LYR
WCS Server: -DUSE_WCS_SVR
SOS Server: -DUSE_SOS_SVR
-------------- MapScript -----------------
PHP MapScript: no
$ make
$ sudo make install
All went fine so I'm just wondering what the hell you're doing.
> -----Ursprüngliche Nachricht-----
> Von: Luís de Sousa [mailto:luis.a.de.sousa at gmail.com]
> Gesendet: Donnerstag, 30. August 2012 11:56
> An: thomas bonfort
> Cc: Eichner, Andreas - SID-NLKM; mapserver-users at lists.osgeo.org
> Betreff: Re: [mapserver-users] Error compiling Mapserver 6.0.3
> On 30 August 2012 11:12, thomas bonfort
> <thomas.bonfort at gmail.com> wrote:
> > As already stated multiple times, you have no reason to
> regenerate the
> > lexer yourself, i.e. flex and yacc are *not* a requirement for
> > building. Start off with a fresh directory from a 6.0.3
> tarball, to be
> > sure touch maplexer.c and uninstall flex/yacc, and you
> should be fine.
> I've done that yesterday (or the day before) with both 6.0.3 and
> 6.0.1, please read my messages up thread. I'm not compiling maplexer.c
> myself, I'm just following the instructions at the Mapserver website.
> Thank you for the help in any case,
> Luís
