[mapserver-users] Problem with "ANGLE FOLLOW"
    umn-ms at hydrotec.de
    Mon Dec  3 06:07:38 PST 2012
> Try lowering the BUFFER number? ...
Good idea. But even changing to "BUFFER 0" didn't change anything ...
Problem is still there.
Benedikt
TC Haddad <tchaddad at gmail.com> schrieb am 03.12.2012 13:54:56:
> 03.12.2012 13:55
> An
> "umn-ms at hydrotec.de" <umn-ms at hydrotec.de>
> Kopie
> Thema
> Re: [mapserver-users] Problem with "ANGLE FOLLOW"
> Try lowering the BUFFER number? If each label has a big buffer, then
> less labels can fit...
> Tanya
> On Dec 3, 2012, at 2:56 AM, umn-ms at hydrotec.de wrote:
> > Hi
> > I'm using  ANGLE-FOLLOW in Mapserver 6.2 to label lines.
> > Unfortunately only 5 of 12 features are labeld.
> > I attach an example with data and mapfile. It can be used with
> > All features are drawn, but most of them are not labeld, although there
> > should be enough space for all labels.
> > (To activate this example, one has to add arialbd.ttf in the
> > test-directory. I didn't attach this one, because of size-limits
> > in this mailing-list...)
> > Without "ANGLE FOLLOW" all labels are drawn.
> > Benedikt
> > #Layerdefinition:
> > LAYER
> >  NAME "Striche"
> >  TYPE LINE
> >  STATUS ON
> >  DEBUG 5
> >  TEMPLATE "dummy.html"
> >  TOLERANCE 0
> >  DATA "Striche"
> >  LABELITEM "name"
> >  CLASS
> >      NAME "Hauptsammler"
> >      LABEL
> >        COLOR 0 0 0
> >        OUTLINECOLOR 255 255 255
> >        OUTLINEWIDTH 6
> >        TYPE truetype
> >        SIZE 5
> >        MINDISTANCE 0
> >        ANGLE FOLLOW
> >        FORCE TRUE
> >        FONT "arial-bold"
> >        BUFFER 10
> >      END
> >      STYLE
> >        OUTLINECOLOR 0 0 0
> >        WIDTH 3
> >        PATTERN 5 5 END
> >        LINECAP BUTT
> >      END
> >  END
> > END
> > (See attached file: missinglabel.zip)
> > <missinglabel.zip>
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
