[mapserver-users] Problem with "ANGLE FOLLOW"
umn-ms at hydrotec.de
Mon Dec 3 08:38:46 PST 2012
@Christy Nieman and @Olivier Courtin: Thank you very much!
This solved the issue.
I tried "MAXOVERLAPANGLE <shameless big number>" and all labels were drawn.
We'll read the blog to find a reasonable solution.
Thank's
Benedikt
mapserver-users-bounces at lists.osgeo.org schrieb am 03.12.2012 15:35:20:
> Olivier Courtin <olivier.courtin at gmail.com>
> Gesendet von: mapserver-users-bounces at lists.osgeo.org
> 03.12.2012 15:35
> An
> mapserver-users at lists.osgeo.org
> Kopie
> Thema
> Re: [mapserver-users] Problem with "ANGLE FOLLOW"
> Hi,
> For same kind of need (i.e hydrologic line to label), i've found that:
> - Your lines must be long enough to allow the label to fit on
> (seems already your case, as it works for you without ANGLE FOLLOW)
> - You have to increase MAXOVERLAPANGLE property
> - Your lines have to be as smooth as possible
> Below a sample of such a thing with two layers, one with the data
> itself and one another using a generalization trought PostGIS
> ST_Simplify to help the geometry to be smoother enough
> LAYER
> NAME "label"
> METADATA
> "ows_title" "Label des cours d'eau Carthage AERMC"
> "ows_extent" "573401 6050407 1242369 6811885"
> "ows_featureid" "gid"
> END
> PROJECTION
> "init=epsg:2154"
> END
> TYPE line
> STATUS on
> DATA "geom from (SELECT gid, ST_simplify(geom, 200) As geom
> , toponyme, classe::integer
> FROM aermc.cours_eau WHERE toponyme IS NOT NULL)
> AS foo using unique gid using srid=2154"
> CONNECTIONTYPE postgis
> CONNECTION "host=XXXX port=5432 dbname=XXXX user=XXXX"
> LABELITEM toponyme
> CLASSITEM classe
> CLASS
> EXPRESSION ([classe] <= 2)
> LABEL
> COLOR 0 0 0
> OUTLINECOLOR 210 210 210
> TYPE TRUETYPE
> FONT vera
> SIZE 10
> ANTIALIAS TRUE
> POSITION UC
> ANGLE FOLLOW
> PARTIALS FALSE
> MINFEATURESIZE auto
> REPEATDISTANCE 500
> MAXOVERLAPANGLE 45
> END
> END
> CLASS
> EXPRESSION ([classe] <= 4)
> LABEL
> COLOR 30 30 30
> TYPE TRUETYPE
> FONT vera
> SIZE 8
> ANTIALIAS TRUE
> POSITION UC
> ANGLE FOLLOW
> PARTIALS FALSE
> MINFEATURESIZE auto
> MAXOVERLAPANGLE 40
> END
> END
> CLASS
> LABEL
> COLOR 60 60 60
> TYPE TRUETYPE
> FONT vera
> SIZE 8
> ANTIALIAS TRUE
> POSITION UC
> ANGLE FOLLOW
> PARTIALS FALSE
> MINFEATURESIZE auto
> MAXOVERLAPANGLE 40
> END
> END
> END
> LAYER
> NAME "cours_eau"
> METADATA
> "ows_title" "Cours d'eau Carthage"
> END
> PROJECTION
> "init=epsg:2154"
> END
> TYPE line
> STATUS on
> DATA "geom from (SELECT gid, geom , classe::integer FROM
> aermc.cours_eau
> CLASSITEM classe
> CLASS
> STYLE
> COLOR 33 33 210
> WIDTH 5
> END
> END
> CLASS
> STYLE
> COLOR 66 66 210
> WIDTH 3
> END
> END
> CLASS
> STYLE
> COLOR 99 99 210
> WIDTH 1
> END
> END
> END
> HTH,
> Olivier_______________________________________________
