[mapserver-users] Mapserver useful for ordinary sites or not?
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Dec 5 11:17:47 PST 2012
Try google "centos mapserver install cpanel" it looks like it has some
promising leads.
-Steve W
On 12/5/2012 1:48 PM, Saka Royban wrote:
> Hi Stephen
> It's CentOS and i've extracted that file from Enterprise Linux GIS.
> I ONLY have cPanel in front myself. How can i run that command?
> Sorry but i really don't know.
> Thanks
> ----- Original Message -----
> From: Stephen Woodbridge <woodbri at swoodbridge.com>
> To: mapserver-users at lists.osgeo.org
> Cc:
> Sent: Wednesday, December 5, 2012 10:01 PM
> Subject: Re: [mapserver-users] Mapserver useful for ordinary sites or not?
> It is probably failing because of missing dependency.
> Try this from the command line:
> /path/to/cgi-bin/mapserver -v
> This will give a more useful error message you can read.
> That said, extracting the binary and copying it to the cgi-bin is not
> going to work in most cases because the whole point of package systems
> like rpm it to find and install the dependencies.
> What version of linux is installed on your host?
> There is probably a one line command that we can give you to install
> mapserver the correct way.
> -Steve W
> On 12/5/2012 1:16 PM, Saka Royban wrote:
> > Thanks for your answer
> > After lots of try, i found that i can extract mapserver binary from rpm
> > using 7zip. I put that executable file to cgi-bin and call it via
> > address bar but no success, just 500 Internal Server Error. (I know
> > mapserver has some dependencies but in spite of that it everything was
> > right it should display a nice error)
> > Contacting with guys in host provider, they pointed me to
> > http://mapserver.org/installation/unix.html#installation and finally
> > told me there is no shell access to run this commands.
> > I'm familiar with structure of mapserver cause of working with MS4W in
> > my own computer. In addition, i've checked CGI-bin directory by running
> > some perl script and everything is O.K. They really provide CGI
> capability.
> > Now, i don't know what can i do more. (I'm not familiar with Linux,
> > although i know what running a shell command means. I've been around
> > computer since DOS age)
> > Thanks in advance for helpful advices.
> > Regards
> > From: Mr. Puneet Kishor <punk.kish at gmail.com
> <mailto:punk.kish at gmail.com>>
> > To: MapServer OSGEO <mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>>
> > Cc:
> > Sent: Wednesday, December 5, 2012 9:24 PM
> not?
> > On Dec 5, 2012, at 9:40 AM, Saka Royban <sakaroyban at yahoo.com
> <mailto:sakaroyban at yahoo.com>
> > <mailto:sakaroyban at yahoo.com <mailto:sakaroyban at yahoo.com>>> wrote:
> > > Hi guys
> > > After a lot of effort to use CGI mapserver in my own site and finally
> > leaving hope to find a solution, i came here to ask whether maserver is
> > useful just for dedicated servers or VPSs really?
> > > I (and as it sounds, most of users) have just bought some space from
> > a host provider (i.e Linux) with a CGI-bin directory which as my host
> > provider says is able to run CGI applications written in perl and C/C++.
> > > I have searched a lot but as it appears no one has been successful to
> > run CGI mapserver in its CGI-bin folder. Am i right?
> > You are not right. MapServer is surprisingly easy to set up and get
> > working, at least for basic and mid-complexity use cases.
> > > CGI mapserver is useful just when shell access is available? Should i
> > switch to Mapscript? Or maybe, buy a windows host with CGI capability?
> > Unless you figure out what you are doing wrong, you can't set it right.
> > Why don't you post your issues here in detail (how you are setting
> > things up, have you followed the tutorial, etc.) along with the errors
> > you are getting (general description as well as specific error messages.
> > I am sure one of us will be able to help you.
> > > Your help would nicely be appreciated. I'm really got stuck and
> confused.
> > Yup, frustration is a common feeling when things don't work, but really,
> > no need to give up. "You can do it, we can help"
> > Puneet Kishor
> > Science and Data Policy at Creative Commons
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
