[mapserver-users] Hindi and Thai text rendering
Peter Mallen
peter.mallen at airborne.aero
Fri Dec 14 15:20:19 PST 2012
Hello Everyone,
I am re-posting this with a corrected link provided below.
We are having issues displaying Hindi in Map Server. The characters
display correctly in text editors we use, as well as excel, open office
documents and in our sqlite database. Certain characters appear to flip
around when displaying in Map Sever. We have tried various different
fonts including: arialuni, devangari, gargi, etc. We have also tried
using several data types: shapefiles, sqlite databases.
The following is a link showing how the Hindi characters should display:
http://translate.google.com/#hi/en/%E0%A4%AE%E0%A5%87%E0%A4%95%E0%A5%8D%
E0%A4%B8%E0%A4%BF%E0%A4%95%E0%A5%8B%20%E0%A4%B8%E0%A4%BF%E0%A4%9F%E0%A5%
80
I have included a basic Map File where I am using the TEXT tag to
display the Hindi translation using an HTML string of entities.
MAP
NAME 'Simple'
STATUS ON
SIZE 1280 768
EXTENT -180 -90 180 90
UNITS MILES
IMAGECOLOR 0 0 70
IMAGETYPE PNG
#CONFIG "MS_ERRORFILE"
"/data2/Hindi_Testing/mapserver.log" #change this to match your
configuration
DEBUG 5
FONTSET fontset.txt #This will need to be updated to
the location of the users fontset.txt. We are using arialuni.
LAYER
DEBUG 5
NAME cities1
TYPE annotation
STATUS DEFAULT
FEATURE
POINTS -99.169998 19.42 END
END
CLASS
#This HTML string is for 'Mexico City' translated into
Hindi. Mapserver does not display this correctly.
TEXT
'मेक्सिको
;सिटी'
LABEL
FONT "arialuni"
TYPE truetype
ENCODING 'UTF-8'
SIZE 30
COLOR 200 200 0
POSITION CC
PARTIALS FALSE
ALIGN center
END
END
END
END # Map File
Thank You,
Peter Mallen
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
mapserver-users-request at lists.osgeo.org
Sent: Friday, December 14, 2012 3:05 PM
To: mapserver-users at lists.osgeo.org
Subject: mapserver-users Digest, Vol 59, Issue 24
Send mapserver-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/mapserver-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
mapserver-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than
"Re: Contents of mapserver-users digest..."
Today's Topics:
1. Re: Reclassify raster cell values (ALT SHN)
2. Raster color table (ALT SHN)
3. Re: Hindi and Thai text rendering (Peter Mallen)
Message: 1
Date: Fri, 14 Dec 2012 22:48:13 +0000
To: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
Cc: "mapserver-users at lists.osgeo.org"
<mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] Reclassify raster cell values
Message-ID:
<CAGFOAzz-RdXUGvO1H=2hjriG4q0fJLcbUy0GAOu7CeAWB20v3w at mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Thank you Rahknonen,
However this is not quite what I expected. If I reclassify a particular
value, all other cells disapear.
This leads me to another question (I'll open another topic too). the
PROCESSING LUT command can be used as a way to build a indexed color
table for 8bit rasters. Is there a way to import a color table ?
Thank you
Andr?
2012/12/10 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> Hi,
> It should be possible to do what you want by using the PROCESSING LUT
> option.
> http://www.mapserver.org/input/raster.html
> -Jukka Rahkonen-
> ________________________________
> > ALT SHN wrote:
> > Hello Everyone,
> > First time Mapserver user here, and I would appreciate some advice
> regarding this problem:
> > I have a Tile Index of single band TIFF rasters (0-255). The rasters
> > are
> displayer fast, and accuratly. However these rasters cover a sea shore
> area, this means that half the rasters are sea territory, wich is
> represented in black (0 cell values)
> > Is there way, in the Mapfile to reclassify the 0 cells to 255 in
> > order
> to turn them white? I know I can always pre process the rasters, but
> I'm talking about forty + files...
> > Thanks in advance,
> Cheers,
> Andr? Mano
> Associa??o Leonel Trindade
> SOCIEDADE DE HIST?RIA NATURAL
> Apartado 25 2564-909 Torres Vedras Portugal Sede e Biblioteca: rua
> Cavaleiros da Espora Dourada, 27A 2560 Torres Vedras
> Laborat?rio de Paleontologia e Paleoecologia: Pol?gono Industrial do
> Alto do Ameal 2565-641 Ramalhal http://alt-shn.blogspot.com
> www.alt-shn.org<http://www.alt-shn.org>
www.alt-shn.org
URL:
<http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121214/d
e8b3112/attachment-0001.html>
Message: 2
Date: Fri, 14 Dec 2012 22:52:09 +0000
Subject: [mapserver-users] Raster color table
Message-ID:
<CAGFOAzzUTQ-SCRMU9Z19J+ZnSo3X4XAJ2MM729NoUxaFk1cERQ at mail.gmail.com>
Is there a way to associate a color table to a 8bit raster so Mapserver
doesn't render it in grayscale?
In the Mapserver documentation, a pallete is refered, but for what I
understood, this applies to the output format, not to a particular
raster.
Is there a workarround for this situation? (other than converting the
raster to RGB)
Thank you,
Andr? Mano
www.alt-shn.org
URL:
<http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121214/b
4370911/attachment-0001.html>
Message: 3
Date: Fri, 14 Dec 2012 17:54:41 -0500
From: "Peter Mallen" <peter.mallen at airborne.aero>
To: <mapserver-users at lists.osgeo.org>
Subject: Re: [mapserver-users] Hindi and Thai text rendering
Message-ID:
<0342A56AD728D64185DB36D9514E2E7E0128CB7B at BE64.exg3.exghost.com>
Content-Type: text/plain; charset="us-ascii"
Hello Everyone,
80
MAP
NAME 'Simple'
STATUS ON
SIZE 1280 768
UNITS MILES
IMAGECOLOR 0 0 70
IMAGETYPE PNG
#CONFIG "MS_ERRORFILE" "/data2/Hindi_Testing/mapserver.log"
#change this to match your configuration
DEBUG 5
FONTSET fontset.txt #This will need to be updated to the
LAYER
DEBUG 5
NAME cities1
TYPE annotation
STATUS DEFAULT
FEATURE
END
CLASS
TEXT
'मेक्सिको
;सिटी'
LABEL
FONT "arialuni"
TYPE truetype
ENCODING 'UTF-8'
SIZE 30
COLOR 200 200 0
POSITION CC
PARTIALS FALSE
ALIGN center
END
END
END
END # Map File
Thank You,
Peter Mallen
Sent: Tuesday, June 19, 2012 6:01 AM
Subject: mapserver-users Digest, Vol 53, Issue 42
Today's Topics:
1. Hindi and Thai text rendering (Ian Walberg)
2. Re: Hindi and Thai text rendering (Jeff McKenna)
3. Re: Hindi and Thai text rendering (Ian Walberg)
4. Re: Hindi and Thai text rendering (Stephen Woodbridge)
5. Re: Hindi and Thai text rendering (Ian Walberg)
6. Mapfile Variables (Matt McClelland)
7. Re: Hindi and Thai text rendering (Stephen Woodbridge)
Message: 1
Date: Mon, 18 Jun 2012 17:45:39 -0400
To: <mapserver-users at lists.osgeo.org>, <mapserver-dev at lists.osgeo.org>
Subject: [mapserver-users] Hindi and Thai text rendering
Message-ID:
<D12323219CEDB24AA8FAE53FF3F59FB40362BF83 at BE28.exg3.exghost.com>
Hello list,
We are seeing some issues displaying Hindi and Thai text, from a quick
search it looks like this may be related to there not being support for
Indic scripts.
Can anyone confirm if these are supported? And if they are not are there
any workarounds?
Many thanks
Ian
URL:
<http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120618/7
24b9741/attachment-0001.html>
Message: 2
Date: Mon, 18 Jun 2012 19:06:09 -0300
From: Jeff McKenna <jmckenna at gatewaygeomatics.com>
Message-ID: <4FDFA651.80507 at gatewaygeomatics.com>
Content-Type: text/plain; charset=ISO-8859-1
On 12-06-18 6:45 PM, Ian Walberg wrote:
> Hello list,
> for Indic scripts.
> there any workarounds?
Hello Ian,
I can for sure confirm that Thai text is supported, as it was one of the
languages tested during the initial implementation of the source code
(see the notes at the bottom of
http://www.mapserver.org/mapfile/labelencoding.html).
There's always a chance that things have changed with MapServer 6.0, but
if you provide a small data sample, font, and simple one layer mapfile I
am sure others on this email list can test and provide feedback for you.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
Message: 3
Date: Mon, 18 Jun 2012 18:46:11 -0400
To: "Jeff McKenna" <jmckenna at gatewaygeomatics.com>,
Message-ID:
<D12323219CEDB24AA8FAE53FF3F59FB40362BF8A at BE28.exg3.exghost.com>
Jeff,
That is encouraging, however our concern is that the character rendering
is not supported.
Regards
Ian
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jeff
McKenna
Sent: Monday, June 18, 2012 3:06 PM
> Hello list,
> for Indic scripts.
Hello Ian,
-jeff
Jeff McKenna
Message: 4
Date: Mon, 18 Jun 2012 23:47:10 -0400
From: Stephen Woodbridge <woodbri at swoodbridge.com>
Message-ID: <4FDFF63E.9000407 at swoodbridge.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
On 6/18/2012 6:46 PM, Ian Walberg wrote:
> Jeff,
rendering
> is not supported.
Ian,
What do you mean by this statement?
What have you tried? ie: what does you mapfile look like, what font are
you using, etc?
For this to work you need the following:
1. a mapserver build with fribidi-0.19.2 2. a truetype fone file that
supports all the glyphs that you need 3. your mapfile and data
configured correctly such that the text in the data is appropriately for
the ENCODING and that that then matches the ttf.
-Steve W
> Regards
> Ian
> From: mapserver-users-bounces at lists.osgeo.org
> McKenna
>> Hello list,
quick
>> for Indic scripts.
> Hello Ian,
the
but
I
you.
> -jeff
> Jeff McKenna
Message: 5
Date: Mon, 18 Jun 2012 23:51:36 -0400
To: "Stephen Woodbridge" <woodbri at swoodbridge.com>,
Message-ID:
<D12323219CEDB24AA8FAE53FF3F59FB40362BF96 at BE28.exg3.exghost.com>
Stephen,
We can provide some examples tomorrow but we are seeing some characters
not matching what is displayed in other applications.
Overall the behaviour appears to match this description
https://github.com/mapserver/mapserver/issues/2591
Regards
Ian
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Monday, June 18, 2012 8:47 PM
> Jeff,
> rendering is not supported.
Ian,
you using, etc?
-Steve W
> Regards
> Ian
> McKenna
>> Hello list,
>> quick
>> for Indic scripts.
> Hello Ian,
> the languages tested during the initial implementation of the source
> code (see the notes at the bottom of
> but if you provide a small data sample, font, and simple one layer
> mapfile I am sure others on this email list can test and provide
feedback for you.
> -jeff
> Jeff McKenna
Message: 6
Date: Tue, 19 Jun 2012 16:15:12 +1000
Subject: [mapserver-users] Mapfile Variables
Message-ID:
<CAGbhREnaqcO=btsGghLV+KbiK+9LZXfo9kCEqpxRSAgAMinjQw at mail.gmail.com>
Hi All
Is is possible create and use variables within a mapfile?
IE I want to store the colour of a road in one place, then reference
that colour in the several style tags
EG
$road_colour_inside = "255 0 0 "
then later in the style tags be able to do color $road_colour_inside
Or something similar.
I am using v6.0
Thanks
Matt :)
URL:
<http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120619/a
f7b4f4a/attachment-0001.html>
Message: 7
Date: Tue, 19 Jun 2012 08:59:41 -0400
To: Ian Walberg <ian.walberg at airborne.aero>
Cc: mapserver-users at lists.osgeo.org
Message-ID: <4FE077BD.1020407 at swoodbridge.com>
Hi Ian,
The symptoms you are describing are similar to what I have run into with
rendering Arabic. What we found was that the TTF we were using was
missing some glyphs related to connecting characters in the script. My
client Identified these and we were able to locate a different font that
had better glyph coverage for Arabic. I don't know anything about Hindi
and Thai so looking at you results will not help, but it does sounds
like the basic rendering is working.
Assuming the above is true, then you would need to identify the
characters that are wrong or missing by there character codes and then
find a font that has support for those codes. If you think fribidi is
not handling things correctly, I have found their mailing list to be
very helpful and they suggested changes to how we used their code in
mapserver in the past to filter out some zero width space utf8 codes
that were causing problems for Arabic.
-Steve W
On 6/18/2012 11:51 PM, Ian Walberg wrote:
> Stephen,
characters
> Regards
> Ian
> Woodbridge
>> Jeff,
> Ian,
are
> you using, etc?
for
> -Steve W
>> Regards
>> Ian
>> McKenna
>>> Hello list,
>>> quick
>>> for Indic scripts.
>> Hello Ian,
> feedback for you.
>> -jeff
>> Jeff McKenna
End of mapserver-users Digest, Vol 53, Issue 42
End of mapserver-users Digest, Vol 59, Issue 24
