[mapserver-users] Using imagemap calls
Andrea Peri aperi2007 at gmail.com
Mon Dec 31 02:10:23 PST 2012
I'm studying the image map configuration to use it.
I see the sample available :
http://mapserver.org/output/imagemaps.html
It is quite clear.
But my use-case is little different.
I know the bbox in another SRS rather than the SRS of shapefile datasource.
So I need (as in the wms) send the request using a BBOX on a different
SRS and also say to the mapserver (imagemap configuration)
the SRS I' m using.
This is easy on a wms call using the SRS parameter.
In the imagemap configuration (cgi) there is a parameter to say the
used SRS to the server for imagemap ?
Thx.
Andrea Peri
qwerty àèìòù
More information about the MapServer-users mailing list
