[mapserver-users] Release of MapServer 6.0.2 and 5.6.8
Alan Boudreault
aboudreault at mapgears.com
Thu Feb 9 11:22:06 EST 2012
MapServer 6.0.2 is now in the UbuntuGIS unstable PPA for Hardy, Lucid,
Natty and Oneiric.
Alan
On 12-02-08 04:12 PM, Daniel Morissette wrote:
> The MapServer team announces the release of MapServer versions 6.0.2 and
> 5.6.8.
> No new functionality has been added. 6.0.2 is a maintenance release that
> fixes a few issues found since 6.0.1 including a recently discovered
> security vulnerability in the handling of WFS filters inside a SLD. The
> list of fixes since 6.0.1 is included at the end of this message.
> Versions 5.6.8 includes fixes for the same WFS Filter security
> vulnerability plus a few bug fixes that were backported since the last
> official release. See the 5.6.8 HISTORY.TXT file for additional
> information.
> Source and binary downloads:
> The source code is available at:
> http://mapserver.org/download.html
> The binary distributions listed in the download page should be updated
> shortly with binaries for the new 6.0.2 release (and in some cases 5.6.8).
> The MapServer Team
> Version 6.0.2 (2012-02-08):
> - Fix security issue with quote escape in WFS GetFeature Filter (#4087)
> - Fixed lexer buffer size issue with single quotes in a string (#4175)
> - Raster layer fails to be drawn if the window is less than half a pixel
> (#4172)
> - Fixed SLD with FILTER doesn't apply properly to database layers (#4112)
> - Fixed a problem with calls to labelInImage() (maplabel.c) when label
> gutter
> and label buffers are both used (#3303). Also changed the usage around that
> function to make it easier to understand. At a result the
> "labelcache_map_edge_buffer" processing option (i.e. gutter) can be
> provided
> as a positive or negative value. (closes #1355 too)
> - Added label->style markers to collision detection (#4133)
> - Fixed single pixel coverages in WCS 2.0 (#4110)
> - Fixed subsetting in WCS 2.0 (#4099)
> - Fixed segfault when calling classObj::updateFromString() with SYMBOL
> (#4062)
> - fix rendering offset on thick GD lines (#3962)
> - fix segfault on join with postgresql tables (#4074)
> - Fixed Python Mapscript does not write COLOR to reference map (#4042)
> - Fixed cannot add a style to a label in PHP/SWIG Mapscript (#4038)
> - Add missing outputFormat support in WFS GetFeature POST XML requests
> (#4052)
> - Fixed schema validity issue for WCS 1.1 GetCoverage responses (#4047)
> - fix centroid geomtransform parser (#4029)
> - PHP MapScript is missing many styleObj properties (#3901)
> - Added GEOMTRANSFORM in writeStyle function
> - WCS 1.0: Fix crash with some _rangeset_axes values (#4020)
> - Changed msDrawVectorLayer() not to cache shapes if attribute binding is
> present after the first style (#3976)
> - Fix mapscript to build when TRUE macro is not defined (#3926)
> - Fix mapscript php build issues with MSVC (#4004)
> - PHP/Mapscript: Segmentation fault when getting complex object using
> PHP 5.2 (#3930)
> - Fixed contains operator in logical expresions (#3974)
> - Fix incorrect rendering of GD lines between 1 and 2 pixels wide (#3962)
> mapserver-users at lists.osgeo.org
Alan Boudreault
http://www.mapgears.com/
