[mapserver-users] Re: from kml styles to mapserver layer
classification
Mr. Puneet Kishor
punk.kish at gmail.com
Mon Feb 20 20:06:17 PST 2012
Mike (and Richard),
Thanks for the advice, but I didn't have to use gdal. As I wrote in another email, 5 or so lines of Perl code extracted the hex color values and inserted them in the Postgres table. From there, it was just a matter of knowing the correct map file syntax. Richard's suggestion of prefixing the # sign was spot on, which I added right in the Pg column. Then, the CLASS STYLE shown below worked really well.
Many thanks all.
On Feb 20, 2012, at 9:27 PM, Smith, Michael ERDC-CRREL-NH wrote:
> Puneet,
> A very recent version of gdal, last couple of weeks, can convert KML
> styles into OGR style strings. MapServer can use those OGR Style strings
> with the AUTO style option.
> Mike
> Michael Smith
> US Army Corps
> Remote Sensing GIS/Center
> On 2/20/12 10:23 PM, "Mr. Puneet Kishor" <punk.kish at gmail.com> wrote:
>> Hi Richard,
>> On Feb 20, 2012, at 9:21 PM, Richard Greenwood wrote:
>>> On Mon, Feb 20, 2012 at 8:05 PM, Mr. Puneet Kishor
>>>> How can I color the polys in the layer with the hex_color values?
>>> COLOR "#ff0000"
>> So, I can use the hex values directly. Cool. But, will the following be
>> sufficient in the map file?
>> LAYER
>> NAME "foo"
>> DATA "the_geom FROM (SELECT gid, hex_color, the_geom FROM t) tmp
>> USING UNIQUE gid USING srid=4326"
>> STATUS ON
>> TYPE POLYGON
>> CLASS
>> STYLE
>> COLOR [hex_color]
>> END
>> END
>> END
>> END
