[mapserver-users] Re: WCS server not
jorgelopez
jorgelopez.physics at gmail.com
Wed Feb 22 01:57:43 PST 2012
Hello Stephan,
As you said, I have seen that for Mapserver version it is advisbale to write
DUMP TRUE in (layer-level) map file but there is no capabilities in the web
browser. 505 Internal Server Error and the following message:
The server encountered an internal error or misconfiguration and was unable
to complete your request.
Please contact the server administrator, etclusi.gis.support at uab.es and
inform them of the time the error occurred, and anything you might have done
that may have caused the error.
More information about this error may be available in the server error log.
I did all related with debug issues and I am obtaining errors to log file
saying
"[Wed Feb 22 09:44:53 2012] [error] [client 158.109.144.146] Premature end
of script headers: mapserv"
According to this, I checked not to be in conflict with INPUT=GDAL and
INPUT=TIFF
MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
I am trying to serve two TIFF Images, one with 1 band and a colour palette
(Land Cover) and another one, Murble Nasa image and 3 bands RGB. So at this
point I dont know if there is a conflict with GDAL library (I dont think so
because shp2img -m file.map -o test.png -all_debug 5 reports in a correct
direction) or one parameters wcs_* related is missing in METADATA section.
Could you give any above-mentioned not explored tips or directly go to MSv6?
Thanks you in advance
Jorge
View this message in context: http://osgeo-org.1560.n6.nabble.com/WCS-server-not-tp4491169p4494377.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
