[mapserver-users] WMS request not enabled
Luís de Sousa
luis.a.de.sousa at gmail.com
Tue Feb 28 05:52:06 PST 2012
Thank you Jukka.
In fact PyWPS is raising some exceptions when invoking mapscript. I'll
upgrade to the trunk right away.
Regards,
Luís
On 28 February 2012 12:32, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> There is nothing wrong in your mapfile, only that you do not have any layers in it. I could repeat the behaviour by removing all the layers from my working mapfiles.
> The error message in misleading. I do not know what message there should be if there are no layers in the service but it is otherwise OK. However, something tells me that this might have corrected in a trunk already.
> -Jukka Rahkonen-
>> -----Alkuperäinen viesti-----
>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
>> Luís de Sousa
>> Lähetetty: 28. helmikuuta 2012 13:08
>> Vastaanottaja: mapserver-users at lists.osgeo.org
>> Aihe: [mapserver-users] WMS request not enabled
>> Dear all,
>> Below goes a map file generated by PyWPS. This file is returning the
>> following error on a GetCapabilities request:
>> msWMSGetCapabilities(): WMS server error. WMS request not enabled.
>> Check wms/ows_enable_request settings.
>> There is a good deal of information on this list about this error,
>> because when MapServer 6.0 was introduced many people didn't have the
>> ows_enable_request parameter set. But PyWPS is correctly setting this
>> parameter, so there's no apparent reason for this error to come up.
>> What else can be causing this? Anything I can do to provide
>> more information?
>> Thank you and regards,
>> Luís
>> MAP
>> CONFIG "MS_ERRORFILE" "stderr"
>> DEBUG 5
>> EXTENT -180 -90 180 90
>> IMAGETYPE "png"
>> NAME "buffer-5989-tmpodARQz"
>> SIZE -1 -1
>> STATUS ON
>> UNITS METERS
>> OUTPUTFORMAT
>> NAME "png"
>> MIMETYPE "image/png"
>> DRIVER "AGG/PNG"
>> EXTENSION "png"
>> IMAGEMODE RGB
>> TRANSPARENT FALSE
>> END # OUTPUTFORMAT
>> PROJECTION
>> "init=epsg:4326"
>> END # PROJECTION
>> LEGEND
>> KEYSIZE 20 10
>> KEYSPACING 5 5
>> LABEL
>> SIZE MEDIUM
>> OFFSET 0 0
>> SHADOWSIZE 1 1
>> TYPE BITMAP
>> END # LABEL
>> STATUS OFF
>> END # LEGEND
>> QUERYMAP
>> SIZE -1 -1
>> STATUS OFF
>> STYLE HILITE
>> END # QUERYMAP
>> SCALEBAR
>> IMAGECOLOR 255 255 255
>> INTERVALS 4
>> LABEL
>> SIZE MEDIUM
>> OFFSET 0 0
>> SHADOWSIZE 1 1
>> TYPE BITMAP
>> END # LABEL
>> SIZE 200 3
>> STATUS OFF
>> UNITS MILES
>> END # SCALEBAR
>> WEB
>> METADATA
>> "wcs_label" "Buffer process using OGR"
>> "wms_onlineresource"
>> "http://localhost/cgi-bin/mapserv?map=/var/www/wps/wpsoutputs/
> pywps-0d1bce24-5d36-11e1-99d2-0021cc5dbe3e.map"
>> "ows_country" "eu"
>> "ows_keywordlist" "GRASS,GIS,WPS"
>> "wms_abstract" "See http://pywps.wald.intevation.org and
>> http://www.opengeospatial.org/standards/wps"
>> "ows_city" "City"
>> "ows_contactperson" "Your Name"
>> "ows_contactposition" "Your Position"
>> "ows_role" "Your role"
>> "ows_enable_request" "*"
>> "ows_contactorganization" "Your Company Name"
>> "ows_accessconstraints" "none"
>> "ows_title" "PyWPS Server"
>> "ows_fees" "None"
>> "wcs_abstract" "See http://pywps.wald.intevation.org and
>> "ows_contactelectronicmailaddress" "login at server.org"
>> "wfs_abstract" "See http://pywps.wald.intevation.org and
>> "ows_address" "Street"
>> "ows_postcode" "000 00"
>> END # METADATA
>> END # WEB
>> END # MAP
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
