[mapserver-users] RE: javascript in html templates
KenHeer1
kenheer1 at gmail.com
Wed Jan 25 18:41:07 EST 2012
I did find the method you outlined but I was still having problems. After
digging deeper into the old javascript, I found where I could intercept the
response and process it as I needed; basically applying the raw html the way
I was before, then executing the script tags to replace the placeholders the
raw html created.
Thanks again for your help, without your suggestions it would have taken me
much longer to find the solution.
Sincerely,
Kenny
Lime, Steve D (DNR) wrote
> Yes, the MapServer-processed template is the AJAX response.
> If you display the AJAX content in a new window (e.g. window.open(...)) or
> frame then javascript in the content will be executed because it's
> essentially a new web page. The problem occurs when you want to display
> the AJAX content in an existing page, say in a new or existing div. The
> browser won't execute the javascript in this case.
> I believe you need to extract the scripts from within the content and
> execute them yourself. One way to do that would be to load the html into
> the div and then do something like:
> // see if there are any scripts in the response to execute
> var popup = document.getElementById("popupDiv");
> var scripts = popup.getElementsByTagName("script");
> for(var i=0;i<scripts.length;i++) eval(scripts[i].text);
> I found this on the web someplace awhile back. There may (and likely are)
> more elegant solutions but this can work. I use it here:
> http://www.dnr.state.mn.us/watertrails/interactive_map/index.html?mapext=407059.5703125+5165944.8242188+418940.4296875+5172755.3710938
> If you click on one of the black recreation icons that returns template
> output that contains javascript. It's executed with the code above.
> Steve
> -----Original Message-----
> From: mapserver-users-bounces at .osgeo
> [mailto:mapserver-users-bounces at .osgeo] On Behalf Of KenHeer1
> Sent: Wednesday, January 25, 2012 11:50 AM
> To: mapserver-users at .osgeo
> Subject: [mapserver-users] RE: javascript in html templates
> I hope you might be able to help me out a little further, I am still a
> little
> new to this.
> I'm using Openlayers to perform my getfeatureinfo request. The Mapserver
> Template file that is returned *is* my ajax response, right?
> That response is a full html page with the javascript in it. If I
> understand
> this right, nothing in a <script> tag will execute on this page, is
> that
> also correct?
> I am vagely familiar with jQuery and ExtJs but everything I've looked at
> seems to require involvement when the initial request is sent, not just
> handling the html response that's returned. Even when I incorporate a
> simple
> jQuery alert into the response page, it's still in the script tag and
> doesn't get fired. It seems like my problem starts because I'm feeding the
> completed mapserver template html file straight to the openlayers function
> and then using openlayers.loadURL and the openlayers popups.
> Instead of using a popup, if I posted the response to a div on the
> original
> page I believe I'd be able to use some of the examples that I found online
> to handle the new, ajax delivered content. But since it's a popup that's
> essentially a separate html page, that won't work, right?
>> The answer here depends on your development framework. It's not a
>> MapServer issue. By default the browser won't execute javascript in the
>> response and you have to work around that. Frameworks like ExtJS provide
>> options to do this via their AJAX classes. Check your framework's (e.g.
>> jQuery, Dojo or whatever) docs for more information. There are also
>> solutions on the web, search for something like "executing javascript in
>> ajax response".
>> Steve
> http://osgeo-org.1560.n6.nabble.com/javascript-in-html-templates-tp4336706p4338841.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
View this message in context: http://osgeo-org.1560.n6.nabble.com/javascript-in-html-templates-tp4336706p4339565.html
