[mapserver-users] Problem querying personal GDB
Bistrais, Bob
Bob.Bistrais at maine.gov
Tue Jul 3 13:12:31 PDT 2012
Please excuse me if this is redundant- I've also posted this to the GeoMoose list, and I can't remember what I've posted where on this issue.
I am building an application with MapServer 6.0.2, and GeoMoose 2.6 on the front end. One of the layers is contained in an ESRI personal Geodatabase, i.e. a Microsoft Access database.
This layer displays properly. I can also do an Identify on it and get expected results. It's when I try to do a Search (a select by attributes) when things fall apart. Checking the error log, I see msEvalExpression(): General error message. Cannot evaluate expression, no item index defined.
It's also worth noting that, if I convert the layer to shapefile and use that in the application, it will work. But there's a few operational considerations that make it preferable to use the GDB. So the problem seems to be with querying the MDB. Does anyone have any ideas?
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120703/3cce8a2a/attachment.html>
