[mapserver-users] Problem querying personal GDB
Bistrais, Bob
Bob.Bistrais at maine.gov
Thu Jul 5 07:08:03 PDT 2012
I see this is in the section for using a PostGIS layer. Is that applicable for an ESRI Personal GDB?
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Tuesday, July 03, 2012 6:01 PM
To: Bistrais, Bob
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Problem querying personal GDB
Bob,
You may need to add a "using unique" clause like "using unique gid" http://www.mapserver.org/input/vector/postgis.html#data-access-connection-method
Best Regards,
Brent Fraser
On 7/3/2012 2:12 PM, Bistrais, Bob wrote:
Please excuse me if this is redundant- I've also posted this to the GeoMoose list, and I can't remember what I've posted where on this issue.
I am building an application with MapServer 6.0.2, and GeoMoose 2.6 on the front end. One of the layers is contained in an ESRI personal Geodatabase, i.e. a Microsoft Access database.
This layer displays properly. I can also do an Identify on it and get expected results. It's when I try to do a Search (a select by attributes) when things fall apart. Checking the error log, I see msEvalExpression(): General error message. Cannot evaluate expression, no item index defined.
It's also worth noting that, if I convert the layer to shapefile and use that in the application, it will work. But there's a few operational considerations that make it preferable to use the GDB. So the problem seems to be with querying the MDB. Does anyone have any ideas?
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120705/51c144f7/attachment-0001.html>
