[mapserver-users] Problem querying personal GDB
Brent Fraser
bfraser at geoanalytic.com
Thu Jul 5 07:57:15 PDT 2012
Bob,
It's just a guess on my part. There was a similar post on the
Geomoose list last year:
http://osgeo-org.1560.n6.nabble.com/Geomoose-users-query-php-and-pgdb-tt4929185.html#a4929188
Best Regards,
Brent Fraser
On 7/5/2012 8:08 AM, Bistrais, Bob wrote:
> I see this is in the section for using a PostGIS layer. Is that
> applicable for an ESRI Personal GDB?
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Tuesday, July 03, 2012 6:01 PM
> *To:* Bistrais, Bob
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Problem querying personal GDB
> Bob,
> You may need to add a "using unique" clause like "using unique gid"
> http://www.mapserver.org/input/vector/postgis.html#data-access-connection-method
> Best Regards,
> Brent Fraser
> On 7/3/2012 2:12 PM, Bistrais, Bob wrote:
> Please excuse me if this is redundant- I've also posted this to
> the GeoMoose list, and I can't remember what I've posted where on
> this issue.
> I am building an application with MapServer 6.0.2, and GeoMoose
> 2.6 on the front end. One of the layers is contained in an ESRI
> personal Geodatabase, i.e. a Microsoft Access database.
> This layer displays properly. I can also do an Identify on it and
> get expected results. It's when I try to do a Search (a select by
> attributes) when things fall apart. Checking the error log, I see
> msEvalExpression(): General error message. Cannot evaluate
> expression, no item index defined.
> It's also worth noting that, if I convert the layer to shapefile
> and use that in the application, it will work. But there's a few
> operational considerations that make it preferable to use the
> GDB. So the problem seems to be with querying the MDB. Does
> anyone have any ideas?
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120705/09a190a5/attachment.html>
