[mapserver-users] World file creation
Jeff Lake
admin at michiganwxsystem.com
Thu Jul 5 15:13:51 PDT 2012
Thanks for the reply ...
Lets ask this ..
I am setting up an open source weather mapping application (php)
I already know most of my target audience will not be able to install
MapServer and or proj4.
I have been trying to get a handle on various map projection's.
decided to use 3
Grid (or flat non-projected)
Mercator
and Lambert Conformal Conic
The first 2 was easy enough creating the needed Classes
to convert Lat/Long to screen pixel X/Y
Lambert has me lost ... every script I have found
be it C, perl, python, or php all return me X/Y in meter's
but for the life of me .. I cannot or have not found the magic
formula to convert the meter's to screen X/Y
I have looked at gPoint, PHPproj4, but they all go no further
then meter's (or it at least seems like it)
-Jeff Lake
MichiganWxSystem.com
WeatherMichigan.net
TheWeatherCenter.net
GRLevelXStuff.com
On 7/4/2012 9:31, Brent Fraser wrote:
> Jeff,
> World files use projected x/y coordinates. Use the Proj4 library
> functions (in Mapscript) to project the upper left and lower right
> spherical lon/lat coordinates to x/y, then use the image size (length,
> width) to calculate the values for the world file
> (http://en.wikipedia.org/wiki/World_file)
> Best Regards,
> Brent Fraser
> On 7/3/2012 8:27 PM, Jeff Lake wrote:
>> Maybe I'm not searching on the correct terms.
>> But what is the magic formula for creating world files ??
>> I have a map of the US with the following projection info
>> ullat=53.3638
>> ullon=-130.964
>> lrlat=18.2977
>> lrlon=-69.1058
>> sp1=0
>> sp2=39
>> cm=-95.5
>> rlat=36.5
>> width=640
>> height=480
>> projection=lambert
>> now how on earth do you figure the meter per pixel??
>> prefer php, but guess I could convert
