[mapserver-users] mapfile to geoserver conversion tools?
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jul 5 18:09:42 PDT 2012
Opened issue: https://github.com/mapserver/mapserver/issues/4380 for this.
On 7/5/2012 8:17 PM, Stephen Woodbridge wrote:
> only 16 of 32 layers generated useful SLD files using perl mapscript;
> Anyone tried this on 6.2? Is this a bug?
> Any ideas how to work around this isue?
> -Steve W
> Details follow:
> MapServer version 6.2.0-beta1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> Here is my perl script:
> woodbri at mappy:~/work/geoserver$ cat mapfile2sld
> #!/usr/bin/perl -w
> use strict;
> use mapscript;
> sub Usage {
> die "Usage: mapfile2sld mapfile out_dir\n";
> my $mf = shift @ARGV || Usage();
> my $dir = shift @ARGV || Usage();
> mkdir $dir, 0777;
> die "Directory '$dir' does not exist or failed to create it! : $!\n"
> unless -d $dir;
> my $oMap = new mapscript::mapObj( $mf );
> for (my $i=0; $i<$oMap->{numlayers}; $i++) {
> my $oLay = $oMap->getLayer($i);
> my $SLD = $oLay->generateSLD();
> my $fname = "$dir/" . $oLay->{name} . ".xml";
> open(OUT, ">$fname") || die "Failed to create '$fname'! : $!\n";
> print OUT $SLD;
> close(OUT);
> 16 of the files contain nothing more than this:
> woodbri at mappy:~/work/geoserver/tiger2011-mc$ cat linear_water.xml
> <StyledLayerDescriptor version="1.0.0"
> xmlns="http://www.opengis.net/sld"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/sld
> http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
> </StyledLayerDescriptor>
> Here is the layer definition:
> LAYER
> NAME "linear_water"
> METADATA
> "ows_title" "Streams and Rivers"
> "ows_srs" "EPSG:4269 EPSG:4326"
> "ows_abstract" "Streams and Rivers from the U.S. Census
> LINEARWATER data layer."
> END
> TYPE LINE
> TILEINDEX "tidx-LINEARWATER"
> PROJECTION
> "+proj=longlat +ellps=GRS80 +datum=NAD83" #EPSG: 4269
> END
> #INCLUDE "map-LINEARWATER.inc"
> # map-LINEARWATER.inc
> MAXSCALEDENOM 15000
> CLASS # water
> STYLE
> COLOR "#a5bfdd"
> WIDTH 1.0
> END
> LABEL
> MAXSCALEDENOM 10000
> TYPE TRUETYPE
> FONT "sans-italic"
> SIZE 8
> COLOR "#627A9D"
> OUTLINECOLOR "#B3C9E2"
> PARTIALS FALSE
> MINDISTANCE 250
> MINFEATURESIZE 10
> BUFFER 4
> ANGLE FOLLOW
> PRIORITY 4
> END
> END
> END
