[mapserver-users] php-mapscript problem and symbolname trying to open a file?
thomas bonfort
thomas.bonfort at gmail.com
Fri Jul 6 04:42:13 PDT 2012
c.f. http://osgeo-org.1560.n6.nabble.com/msLoadMSRasterBufferFromFile-General-error-message-unable-to-open-file-tc4984932.html
thomas
On Fri, Jul 6, 2012 at 10:33 AM, Ben Madin
<lists at remoteinformation.com.au> wrote:
> G'day all,
> I'm not sure if this is two problems, or the second problem is a result of the first. The second problem is that I have a mapfile with multiple sections that look like :
> CLASS
> NAME "Sentinel Positive"
> EXPRESSION "SentPos"
> STYLE
> ANGLE 0
> COLOR 220 20 40
> OFFSET 0 0
> SIZE 8
> SYMBOL "circle"
> END # STYLE
> END # CLASS
> where symbol is :
> SYMBOL # 1
> NAME 'circle'
> TYPE ELLIPSE
> POINTS 1 1 END
> FILLED TRUE
> END
> and when I try to open it, I get :
> msDrawMap(): Image handling error. Failed to draw layer named 'BLU'. <br>
> msLoadMSRasterBufferFromFile(): General error message. unable to open file /usr/local/www/apache22/data/system/mapserver/maps/tmpmapfiles/./circle for reading <br>
> I know that SYMBOL can be a name (in the symbol file) or a filename, but clearly it is getting confused.
> The first problem is that this file is one of several that is meant to be generated by a looping structure in php-mapscript, and I am getting :
> [Fri Jul 06 18:08:13 2012] [notice] child pid 74615 exit signal Abort trap (6)
> Assertion failed: (pixmap->type == MS_BUFFER_BYTE_RGBA), function agg2RenderPixmapSymbol, file mapagg.cpp, line 464.
> [Fri Jul 06 18:08:57 2012] [notice] child pid 74300 exit signal Abort trap (6)
> errors when I try to build the layers (this is the only one that builds). I'm a little short on ideas as to where to go next.
> this is :
> MapServer version 6.0.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Server version: Apache/2.2.22 (FreeBSD)
> PHP 5.4.4 (cli) (built: Jun 20 2012 07:13:50)
> FreeBSD FreeBSD 8.2-RELEASE-p4 amd64
> cheers
> Ben
> mapserver-users at lists.osgeo.org
