[mapserver-users] php_mapscript not being loaded
William Kyngesburye
woklist at kyngchaos.com
Fri Jul 6 06:42:35 PDT 2012
Even more important is that dl() is not even available as of PHP 5.3 in PHP CGI and PHP Apache. You MUST load an extension from php.ini now.
On Jul 6, 2012, at 7:47 AM, Eichner, Andreas - SID-NLKM wrote:
> Hi,
>> dl('php_mapscript.so'); .
>> Which difference about load library in the page and call the
>> library load by apache?
> there's basically no difference except that on some sites this PHP
> extension is not enabled so a script needs to load it explicitly at
> runtime via dl(). If your site uses it seldomly other scripts might run
> faster since the interpreter doesn't need to initialize this extension
> but I don't know that exactly. Regarding functionality it makes
> absolutely no difference.
> mapserver-users at lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
