[mapserver-users] php-mapscript problem and symbolname trying to open a file?
Ben Madin
lists at remoteinformation.com.au
Sun Jul 8 00:05:15 PDT 2012
Thanks Thomas,
you are correct - I was actually not specifying any symbol set at all :
For reasons I can't begin to work out, most of the map file is being written, but the symbol and font lines are failing :
$blumap=new MapObj('',$mapserver_path);
$blumap->set('debug','MS_ON');
$blumap->setprojection('proj=latlong,ellps=WGS84,datum=WGS84',MS_TRUE);
$blumap->set('units',MS_DD);
$blumap->imagecolor->setRGB($sea_bgc[0],$sea_bgc[1],$sea_bgc[2]);
$blumap->setExtent(110, -45, 160, -10);
$blumap->setSymbolSet('/usr/local/www/apache22/data/nahis/mapserver/symbols/standard.symbols');
$blumap->setFontSet($mapserver_path.'fonts/standard.fonts');
$blumap->outputformat->set('name', 'png');
$blumap->outputformat->set('driver', 'agg/png');
is giving me :
MAP
EXTENT 110 -45 160 -10
IMAGECOLOR 230 252 255
IMAGETYPE "png"
NAME "MS"
SIZE 600 600
STATUS ON
UNITS DD
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "agg/png"
Why might the setsymbol and setfont lines be failing to produce mapfile output - but the rest are working fine? Noting that the path in the command is used in other static map files and is working when it is in the file.
If I copy and paste this path into the map file generated by PHP, I get my desired result…
cheers
Ben
On 06/07/2012, at 7:42 PM, thomas bonfort wrote:
> c.f. http://osgeo-org.1560.n6.nabble.com/msLoadMSRasterBufferFromFile-General-error-message-unable-to-open-file-tc4984932.html
> thomas
> On Fri, Jul 6, 2012 at 10:33 AM, Ben Madin
> <lists at remoteinformation.com.au> wrote:
>> G'day all,
>> I'm not sure if this is two problems, or the second problem is a result of the first. The second problem is that I have a mapfile with multiple sections that look like :
>> CLASS
>> NAME "Sentinel Positive"
>> EXPRESSION "SentPos"
>> STYLE
>> ANGLE 0
>> COLOR 220 20 40
>> OFFSET 0 0
>> SIZE 8
>> SYMBOL "circle"
>> END # STYLE
>> END # CLASS
>> where symbol is :
>> SYMBOL # 1
>> NAME 'circle'
>> TYPE ELLIPSE
>> POINTS 1 1 END
>> FILLED TRUE
>> END
>> and when I try to open it, I get :
>> msDrawMap(): Image handling error. Failed to draw layer named 'BLU'. <br>
>> msLoadMSRasterBufferFromFile(): General error message. unable to open file /usr/local/www/apache22/data/system/mapserver/maps/tmpmapfiles/./circle for reading <br>
>> I know that SYMBOL can be a name (in the symbol file) or a filename, but clearly it is getting confused.
>> The first problem is that this file is one of several that is meant to be generated by a looping structure in php-mapscript, and I am getting :
>> [Fri Jul 06 18:08:13 2012] [notice] child pid 74615 exit signal Abort trap (6)
>> Assertion failed: (pixmap->type == MS_BUFFER_BYTE_RGBA), function agg2RenderPixmapSymbol, file mapagg.cpp, line 464.
>> [Fri Jul 06 18:08:57 2012] [notice] child pid 74300 exit signal Abort trap (6)
>> errors when I try to build the layers (this is the only one that builds). I'm a little short on ideas as to where to go next.
>> this is :
>> MapServer version 6.0.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> Server version: Apache/2.2.22 (FreeBSD)
>> PHP 5.4.4 (cli) (built: Jun 20 2012 07:13:50)
>> FreeBSD FreeBSD 8.2-RELEASE-p4 amd64
>> cheers
>> Ben
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
