[mapserver-users] Polygon layer does not cover labels
Sven Geggus
lists at fuchsschwanzdomain.de
Sun Jul 8 10:33:14 PDT 2012
Matt McClelland <matt at wildwalks.com> wrote:
> What would be really nice is a script that can 'tweak' DEM based on map
> data. something that changes the DEM to ensure contours follow shorelines,
> and that the bottom of a valley follows creeks. But I just dream of such a
> tool.
Sound complicated, but clipping might be sufficient for now because this can
be done using postgis.
It should be possible to clip the contours at the edges of the
waterbodies using ST_Difference: Problem solved because no contour
lines means no labels as well :)
So looks like I "just" need to cook up the right SQL query now...
Regards
Sven
Das Internet wird vor allem von Leuten genutzt, die sich Pornografie
ansehen, während sie Bier trinken, es ist daher für Wahlen nicht
geeignet (Jaroslaw Kaczynski)
/me is giggls at ircnet, http://sven.gegg.us/ on the Web
