[mapserver-users] One template for every text type
Andrea Peri
aperi2007 at gmail.com
Mon Jul 9 03:14:32 PDT 2012
Hi Steve,
thx for hint.
I read the doc and also the RFC 36.
I'm having also some doubt.
I try to set this output format:
OUTPUTFORMAT
NAME "delimitazione_fogli_xml"
MIMETYPE "text/xml"
DRIVER "TEMPLATE"
FORMATOPTION "FILE=/pat-to-ex-template-on-layer-level/template_xml.tmpl"
END
at WEB level I set this value:
WEB
METADATA
"wms_feature_info_mime_type" "text/xml"
END
END
And how explained from RFC I comment the template from layer level and try
to add the tag
QUERYABLE TRUE
(But this option seem to be not supported from MapServer 6.2 trunk)
If I remove the template tag from layer level I have this error:
msWMSFeatureInfo(): WMS server error. Requested layer(s) are not queryable.
And if I try to add the QUERYABLE TRUE tag I have
this error:
>Unknown identifier. Parsing error near (QUERYABLE)
So I need to maintain the template ad Layer level. This force the layer to
use the template from that tag instead of the tag from FORMATOPTION.
Also I don't understand how to link the specific format option the a
specific layer.
Thx,
Andrea.
2012/7/6 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
> Hi Andrea: You can define multiple output formats that use the template
> driver. They can each have different names and mime-types. You can even use
> mime subtypes if you needed, say, two XML formats. The MapServer CGI
> supports a parameter called qformat that allows you to change the query
> template to be used. I’m not sure how this works with WFS, probably via
> mime-type.****
> Steve****
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Andrea Peri
> *Sent:* Tuesday, July 03, 2012 5:42 PM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] One template for every text type****
> Hi,
> As report from documentation, MapServer will allow to define a template to
> set the return from an identify.
> I need to define almost two distinct kind of returns:
> One for user (text/plain or text/html) and one for business application
> (text/xml).
> So I like to define not only a template for return an XML but also a
> template for return an html page.
> I don't know how to say to MapServer what template us for text/html and
> what for text/xml.
> Is this possibile ?
> Thx.
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120709/66bef746/attachment.html>
