[mapserver-users] php_mapscript not being loaded
Stefan Schwarzer
stefan.schwarzer at unep.org
Tue Jul 10 04:16:02 PDT 2012
>> And the php -i it spitting out a long list, but no errors.
> The important point with that 'php -i' command is if it contains a
> 'mapscript' section; then compare those results through Apache (does a
> 'phpinfo.php' file through your browser display a section for
> 'mapscript') - these are the issues to check. Often, I'll be able to
> load mapscript through the commandline, but Apache cannot - and this
> will show you where you need to spend your time/effort.
Ah, thanks for clarifying. But no, there are two "map" incidences, but they refer to Protocols (such as ftp, http…)
