[mapserver-users] GetCoverage with WCS 2.0.0: Unknown parameter time
Jonas Eberle
jonas.eberle at gmx.de
Tue Jul 17 10:06:22 PDT 2012
Hi Stephan,
I am using Mapserver 6.0.1.
At the bottom the two layers, within the WEB section I have the the validation block for parameter time.
This was the request with WCS 2.0.0:
http://artemis.geogr.uni-jena.de/cgi-bin/mapserv?map=/home/mapserver/modis/map.map&SERVICE=WCS&REQUEST=GetCoverage&VERSION=2.0.0&coverageID=NDVIData&format=GTiff&time=2012-04-01
The following request works with WCS 1.0.0:
http://artemis.geogr.uni-jena.de/cgi-bin/mapserv?map=/home/mapserver/modis/map.map&SERVICE=WCS&REQUEST=GetCoverage&VERSION=1.0.0&coverage=NDVIData&format=GTiff&time=2012-04-01&CRS=EPSG:4326&RESX=0.05&RESY=0.05
Thanks,
Jonas
WEB
VALIDATION
'time' '^[0-9\-]+$'
END
END
LAYER
NAME 'time_idx_test'
TYPE POLYGON
CONNECTIONTYPE POSTGIS
CONNECTION "host=localhost dbname=** user=**
password=****** port=5432"
DATA "geom from mod13c2_ndvi"
METADATA
"ows_title" "MOD13C2_NDVI TIME INDEX"
"ows_srs" "EPSG:900913 EPSG:4326"
"ows_extent" "49 85 180 44"
"ows_timeextent" "2000-02-01/2012-05-01/P1M"
"ows_timeitem" "date"
"ows_timedefault" "2012-05-01"
"ows_enable_request" "*"
END
FILTERITEM 'date'
FILTER '%time%'
END
LAYER
NAME 'NDVIData'
STATUS ON
DEBUG 5
TYPE RASTER
TILEITEM 'location'
TILEINDEX 'time_idx_test'
PROJECTION
"init=epsg:4326"
END
METADATA
"wcs_label" 'NDVI data'
"ows_extent" "49 44 180 85"
"wcs_size" "7200 3599"
"wcs_bandcount" "1"
"ows_srs" 'EPSG:4326'
"wcs_rangeset_axes" 'bands'
"wcs_rangeset_name" 'bands'
"wcs_timeposition" "2000-02-01,2000-03-01,2000-04-01,2012-04-01"
"wcs_timeitem" 'date'
"wcs_enable_request" "*"
END
END
----- Ursprüngliche Mail -----
> Hi Jonas,
> which version of MapServer are you using? I guess variable
> substitution
> should also be available in WCS 2.0. Could you send a short Mapfile
> and
> request to reproduce the behavior?
> cu
> Stephan
> On Tue, 2012-07-17 at 11:51 -0500, Jonas Eberle wrote:
> > Hi list,
> > I tried to use WCS 2.0.0 with Mapserver. Having time series layers
> > with a tile index layer, I used variable substitution for the
> > different times. This works fine for WCS 1.0.0.
> > Trying the GetCoverage request with WCS 2.0.0 I get the following
> > error message right after executing the request:
> > msWCSParseRequest20(): WCS server error. Unknown parameter: 'time'.
> > Is there an other possibility to use variable substitution with
> > GetCoverage request in WCS 2.0.0?
> > Thanks,
> > Jonas
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
