[mapserver-users] wms_bbox_extended "true" only works with < 15 EPSG code definitions
Martin Kofahl
M.Kofahl at gmx.net
Tue Jul 17 13:42:03 PDT 2012
Hi Astrid,
please update your proj4 lib, see http://trac.osgeo.org/proj/ticket/100.
Martin
-------- Original-Nachricht --------
> Datum: Tue, 17 Jul 2012 21:26:39 -0000
> Von: "Astrid Emde" <astrid.emde at wheregroup.com>
> An: mapserver-users at lists.osgeo.org
> Betreff: [mapserver-users] wms_bbox_extended "true" only works with < 15 EPSG code definitions
> Hello,
> I want to use the Parameter wms_bbox_extended "true" to calculate the
> extent for all the supported EPSGs.
> see
> http://mapserver.org/ogc/wms_server.html
> The Capabilities document looks fine as long as I only define < 15 codes.
> The XML breaks at different points with more EPSG codes (but I need > 15
> for INSPIRE)
> Definition could look like this:
> WEB
> WMS_BBOX_EXTENDED 'true'
> WMS_SRS 'EPSG:31466 epsg:31467 epsg:31468 epsg:4326 EPSG:25832
> EPSG:25833 EPSG:3034 EPSG:3035 EPSG:3038 EPSG:3039 EPSG:3040 EPSG:3041
> EPSG:3042 EPSG:3043 EPSG:3044 EPSG:3045 EPSG:3046 EPSG:3047'
> END
> When I disable the parameter wms_bbox_extended "false" (or I do not define
> the parameter) the Capabilities XML is fine, but does not contain the
> bboxes.
> I tested with MapServer 6.0.2 and MapServer 6.2beta1.
> I also created a bug ticket at github
> https://github.com/mapserver/mapserver/issues/4395
> It is not an urgent issue. Just wanted to notice it.
> Astrid
