[mapserver-users] wms_bbox_extended 'true' only works with < 15 EPSG code definitions
Astrid Emde
astrid.emde at wheregroup.com
Wed Jul 18 12:01:21 PDT 2012
Hello Martin,
thanks for the information and the link.
And thanks to jef for the patch.
I closed my MapServer ticket again.
Astrid
On Tue, July 17, 2012 8:42 pm, Martin Kofahl wrote:
> Hi Astrid,
> please update your proj4 lib, see http://trac.osgeo.org/proj/ticket/100.
> Martin
> -------- Original-Nachricht --------
>> Datum: Tue, 17 Jul 2012 21:26:39 -0000
>> Von: "Astrid Emde" <astrid.emde at wheregroup.com>
>> An: mapserver-users at lists.osgeo.org
>> Betreff: [mapserver-users] wms_bbox_extended "true" only works with < 15
>> Hello,
>> I want to use the Parameter wms_bbox_extended "true" to calculate the
>> extent for all the supported EPSGs.
>> see http://mapserver.org/ogc/wms_server.html
>> The Capabilities document looks fine as long as I only define < 15
>> codes. The XML breaks at different points with more EPSG codes (but I
>> need > 15 for INSPIRE)
>> Definition could look like this:
>> WEB
>> WMS_BBOX_EXTENDED 'true'
>> WMS_SRS 'EPSG:31466 epsg:31467 epsg:31468 epsg:4326 EPSG:25832
>> EPSG:25833 EPSG:3034 EPSG:3035 EPSG:3038 EPSG:3039 EPSG:3040 EPSG:3041
>> EPSG:3042 EPSG:3043 EPSG:3044 EPSG:3045 EPSG:3046 EPSG:3047'
>> END
>> When I disable the parameter wms_bbox_extended "false" (or I do not
>> define the parameter) the Capabilities XML is fine, but does not contain
>> the bboxes.
>> I tested with MapServer 6.0.2 and MapServer 6.2beta1.
>> I also created a bug ticket at github
>> https://github.com/mapserver/mapserver/issues/4395
>> It is not an urgent issue. Just wanted to notice it.
>> Astrid
>> mapserver-users mailing list mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Mit freundlichen Grüßen
Astrid Emde
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
