[mapserver-users] Specify resolution (or pixel size) in WMS requests
Astrid Emde
astrid.emde at wheregroup.com
Fri Jul 20 00:42:29 PDT 2012
Hi Thomas,
I opened up the ticket for Thekla on github
https://github.com/mapserver/mapserver/issues/4401
Thanks for your help
Astrid
Am 18.07.2012 20:49, schrieb thomas bonfort:
> Thekla,
> can you open a ticket for this one please ? I'll try to have a look at
> it before the 6.2 release, but can't promise anything...
> thanks,
> thomas
> On Mon, Jul 16, 2012 at 12:13 PM, Thekla Wirkus
> <thekla.wirkus at wheregroup.com> wrote:
>> Hello,
>> last december 2011 Astrid wrote a mail about the behaviour of RESOLUTION and
>> DEFRESOLUTION. We tested again with MapServer
>> 6.2 and here are the results. The size of the symbols, texts and lines was
>> not like we expected. They were often too small.
>> Have a look at the mail from 14. december 2011
>> http://lists.osgeo.org/pipermail/mapserver-users/2011-December/071077.html
>> We tested with MAP.RESOLUTION=288&MAP.DEFRESOLUTION=72, SIZEUNINTS Meters,
>> the scaled layers with SYMBOLSCALEDENOM 10000.
>> http://localhost/cgi-bin/mapserv62b1?map=/data/umn/resolution/map/resolution_test.map&MAP.RESOLUTION=288&MAP.DEFRESOLUTION=72"&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=notscaledPoint,scaledPoint,notscaledLine,scaledLine,notscaledPolygon,scaledPolygon,Polygon_with_symbols,notscaledLabel,scaledLabel&STYLES=,,,,,,,,&SRS=EPSG:31466&BBOX=2517600,5672315,2518960,5673675&WIDTH=2000&HEIGHT=2000&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_xml
>> The behaviour of MapServer 6.0 and MapServer 6.2 is just the same. This time
>> we have a demo project where we tried the different cases. You can download
>> it at:
>> UMN:
>> https://svn.wheregroup.com/download/mapserver_resolution.zip
>> PDF:
>> https://svn.wheregroup.com/download/mapserver_resolution_pdf.zip
>> Results:
>> POINTS
>> * scaled or not scaled Points/Symbols: displayed correct, scaled and
>> notscaled are the same in the map
>> LINES
>> * scaled lines: displayed correct
>> * unscaled lines: too small (1:2000, 1:5000, 1:1000), correct (1:20000)
>> POLYGON
>> * scaled Polygone/Outline: displayed correct
>> * not scaled Polygone/Outline: too small (1:2000), correct (1:5000,
>> 1:10000,1:20000)
>> * scaled or not scaled Polygone with symbols: displayed correct
>> LABEL
>> * scaled Label: too small
>> * not scaled Label: too big (1:1000, 1:2000, 1:5000, too small (1:20000)
>> For us it would be good to get this problem solved, as at the moment we
>> generate a copy of the mapfile for the print with symbol- and labelsize
>> multiplyed with factor 4. It would be charming to solve the print with one
>> mapfile. We could do testing and maybe I could look for sponsoring too.
>> Is there someone else interested to solve this? Is there a ticket already?
>> Thekla
>> On 14.12.2011 17:44, Astrid Emde wrote:
>> Hello,
>> we tried the parameter MAP.RESOLUTION AND MAP.DEFRESOLUTION with
>> MapServer 6.0.1 and made the following observations.
>> We tested with RESOLUTION=288&MAP.DEFRESOLUTION=72
>> The size of the symbols and textes was not like we expected. They were
>> often too small.
>> We tested with and without the parameter SYMBOLSCALEDENOM
>> 1.) without SYMBOLSCALEDENOM (none scaled, fix size) ok are:
>> * lines (not scaled) are dispayed correct (ok)
>> * outlines (not scaled) of polygones are dispayed correct (ok).
>> * symbols (not scaled) are displayed correct (ok).
>> * textes (not scaled) are displayed correct (ok).We tested not scaled
>> texts without SYMBOLSCALEDENOM: It's displayed different weather
>> MINSIZE/MAXSIZE is existing or not.
>> 2.) with SYMBOLSCALEDENOM
>> NOT ok:
>> * Scaled symbols are displayed incorrect - too small.
>> * Scaled lines are dispayed incorrect - too small.
>> * scaled outlines of polygones are dispayed incorrect.
>> * Scaled text are dispayed incorrect - too small.
>> Astrid
>> thomas bonfort schrieb:
>> cgi controls should do the trick?
>> http://....../?SERVICE=WMS&....&MAP.RESOLUTION=144&MAP.DEFRESOLUTION=96
>> thomas
>> On Mon, Dec 5, 2011 at 17:43, Peter Hopfgartner
>> <peter.hopfgartner at r3-gis.com> wrote:
>> Basically, I am looking for a way to something analogous to
>> DEFRESOLUTION in
>> a WMS request. The standard says, that a pixel is 0.28 mm x 0.28 mm
>> (25.4/0.28 ~= 90.71 DPI). I could not found a way to change this in the
>> WMS
>> 1.3.0 standard.
>> Is there a MapServer vendor parameter, similar to the one in GeoServer,
>> http://docs.geoserver.org/latest/en/user/services/wms/vendor.html#format-options
>> Peter
>> Peter Hopfgartner R3 GIS http://www.r3-gis.com
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Thekla Wirkus
>> GIS-Consultant
>> Aufwind durch Wissen!
>> Qualifizierte OpenSource-Schulungen
>> bei der www.foss-academy.eu
>> WhereGroup GmbH & Co. KG
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Fon: +49 (0)228 / 90 90 38 - 34
>> Fax: +49 (0)228 / 90 90 38 - 11
>> Email: thekla.wirkus at wheregroup.com
>> www.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
>> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Mit freundlichen Grüßen
Astrid Emde
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Komplementärin:
vertreten durch:
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
