[mapserver-users] Can Map Server serve non WMS services?
Sowmya Tiramdasu
stiramdasu at qcoherent.com
Fri Jul 20 11:23:07 PDT 2012
Hi Steve,
Even I am new to the company. So do not have much details. But I think ,
The GetProfileView operation returns a profile view of LIDAR data. Upon
receiving a GetProfileView request, a WMS shall either satisfy the request
or issue a service exception.
The WMS Server we have deals with LIDAR DATA (LAS Files). So when we draw a
line on the display lidar data and send a request for the getProfileView, we
get an image back as response if everything happened good. Else we get a
service exception.
The key value pairs ( parameters) passed along with getProfileView operation
are mentioned in the URL I specified in my previous email. I hope this
information may give you some additional understanding.
Do you think I can use mapscript to make calls to any service ( NOT WMS) and
render the response image as a layer along with other shape file data
layers?
Thanks a lot for trying to help me. I am extremely sorry for giving you
limited info, I myself do not know much about all this . Sorry!
Thanks,
Sowmya.
_______________________________
Sowmya Tiramdasu
QCoherent Software
9668 Madison Blvd., Suite 202
Madison, AL 35758
(256) 461-8289 Telephone
(256) 461-8249 Fax
www.geocue.com
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Friday, July 20, 2012 12:35 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Can Map Server serve non WMS services?
Hi Sowmya,
Since you are making a non-standard WMS request GetProfileView, i doubt
that anyone here knows what that does, and as such, is probably not
going to be able to help you. You need to provide a detailed description
of what GetProfileView does, like what are the inputs, what is the
expect output, and how is it generated.
That said, someone programmed that up on your side and it is likely that
they would have to program support for that using mapserver as a tools
set and maybe using something like mapscript. In general, mapserver is a
map rendering and querying engine that has some additional
geo-processing tools and access to most core features for programming
using mapscript.
Hope this helps,
Steve W
On 7/20/2012 1:00 PM, Sowmya Tiramdasu wrote:
> Hi Steve,
> Thanks for the prompt reply. The request url for my service function is
as
> follows :
http://localhost:8080/sample?FORMAT=image/jpeg&EXCEPTIONS=INIMAGE&BGCOLOR=0x
000000&LAYERS=Points,Boundaries&STYLES=GroundElevation,Red&SERVICE=WMS&VERSI
ON=1.1.1&REQUEST=GetProfileView&SRS=EPSG:26910&LEFT_XY=491646.2272727273,545
8251.454545454&RIGHT_XY=492102.95454545453,5458268.909090909&DEPTH=20&SHOW_D
RAPELINE=FALSE&SHOW_GRATICULE=TRUE&WIDTH=833&HEIGHT=222&COLORIZATION=Classif
> ication&FILTER=All
> I guess this should give you some idea. Let me know if you want to know
any
> additional details.
> So can you please give me an outline how I can use Map server to consume
the
> image coming from my above service? Also can you provide sample map file
> entries to get this served up.
> Thanks in advance,
> Sowmya.
> Sowmya Tiramdasu
> QCoherent Software
> Madison, AL 35758
> (256) 461-8249 Fax
> www.geocue.com
> From: Lime, Steve D (DNR) [mailto:Steve.Lime at state.mn.us]
> Sent: Friday, July 20, 2012 10:16 AM
> To: Sowmya Tiramdasu; mapserver-users at lists.osgeo.org
> Subject: RE: [mapserver-users] Can Map Server serve non WMS services?
> We would have to know more about what the extensions do and how they are
> implemented to comment more in detail. There are certainly options. For
> example, you could use MapScript OWS support and develop a custom service
> that way. Another option would be to use GetFeatureInfo request paired
with
> different responses (via template perhaps) to change the nature of the
> information returned.
> Depending on how the extensions are implemented you might also be able to
> support the different response types using mod-rewrite or something like
> that.
> Steve
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Sowmya
> Tiramdasu
> Sent: Friday, July 20, 2012 9:32 AM
> Subject: [mapserver-users] Can Map Server serve non WMS services?
> Hi,
> We have a wms server. It also has some extensions . There are three
extra
> calls( like GetProfileView etc) other than getCapabilities, GetMap and
> GetFeatureInfo calls. Can I use map server to serve up my none wms calls?
> Any help would be greatly appreciated.
> Thanks,
> Sowmya.
> Sowmya Tiramdasu
> QCoherent Software
> Madison, AL 35758
> (256) 461-8249 Fax
> www.geocue.com
