[mapserver-users] ArcInfo Grid with MapServer
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jul 23 08:50:13 PDT 2012
Jorge,
You have problems with some of your layer definitions. Look at:
pegasosdi.uab.es/ogc/wmstest?service=WMS&version=1.1.1&request=getCapabilities
and search for "WARNING", probably once you fix these issues it will
work fine. For example this layer loads ok and has no warning:
http://pegasosdi.uab.es/ogc/wmstest?service=WMS&version=1.1.1&request=getMap&LAYERS=GLOBCORINE_2009&srs=EPSG:4326&BBOX=-26,26,45,72&WIDTH=600&HEIGHT=500&FORMAT=image/png
-Steve W
On 7/23/2012 11:21 AM, jorgelopez wrote:
> Hello again:
> Thank you R.J. for your soonly reply. I have set STATUS ON|DEFAULT for my
> layer but it does not work.
> My request is as following:
> http://pegasosdi.uab.es/ogc/wmstest?service=WMS&version=1.1.1&request=getMap&LAYERS=JRC_SRTM90&srs=EPSG:4326&BBOX=-26,26,45,72&WIDTH=600&HEIGHT=500&FORMAT=image/png
> but no map image on my browser. No errors on Apache/Mapserver log but when I
> connect to my map server from ArcMap client there is a error message that
> does not appear when browser is used.
> One or more layers failed to draw:
> TEST: WMS service exceptions:-Service Error Code:LayerNotDefined
> Service Error Description: msWMSLoadGetMapParams(): WMS server error.
> Invalid layer(s) given in the LAYERS parameter.
> Any ideas about this?
> Thanks
> Jorge
> View this message in context: http://osgeo-org.1560.n6.nabble.com/ArcInfo-Grid-with-MapServer-tp4990112p4990116.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
