[mapserver-users] SLD TextSymbolizer in 6.1-dev
jlundnielsen
jolni at KMS.dk
Wed Jul 25 06:16:47 PDT 2012
Thanks for joining in :-)
Unfortunately it doesn't seem to make a difference adding the
PropertyName tag inside the Label tag.
Fra: Eichner, Andreas - SID-NLKM [via OSGeo.org]
[mailto:ml-node+s1560n4990747h82 at n6.nabble.com]
Sendt: 25. juli 2012 14:28
Til: Nielsen, Jonas Lund
Emne: Re: SLD TextSymbolizer in 6.1-dev
> Does anyone have an idea what might be the problem here?
Can you try with
<Label><PropertyName>KOMNAVN</PropertyName></Label>
instead of
> <TextSymbolizer>
> <Label>KOMNAVN</Label>
> </TextSymbolizer>
It seems msSLDParseTextParams() tries to read the string value of
Label/PropertyName to build the expression but msSLDGenerateTextSLD()
writes only Label with the LABELITEM as text content.
HTH
mapserver-users mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/mapserver-users
If you reply to this email, your message will be added to the discussion
below:
http://osgeo-org.1560.n6.nabble.com/SLD-TextSymbolizer-in-6-1-dev-tp4984
223p4990747.html
To unsubscribe from SLD TextSymbolizer in 6.1-dev, click here
<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsu
bscribe_by_code&node=4984223&code=am9sbmlAS01TLmRrfDQ5ODQyMjN8NjY2MTMxNj
c0> .
NAML
<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macr
o_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespac
es.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.w
eb.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemai
l.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%
3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/SV-SLD-TextSymbolizer-in-6-1-dev-tp4990757.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120725/24b3f7c0/attachment.html>
