[mapserver-users] Resolution of PDF Output
Sven Geggus
lists at fuchsschwanzdomain.de
Thu Jul 26 07:55:58 PDT 2012
Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> What version are you using?
Have been using some git trunk back from may because of the GAMMA Option I
needed for Ocean Polygons.
> have you tried this with the 6.2-beta?
Just updated to latest trunk to check if the problem still exists and
unfortunately it does.
To clarify what this bug is all about: It is not about mapserer not honoring
the DPI given in the mapfile (it does), but about the generated file
(pdf/svg) not knowing about this value. This results in PDF Files which are
way to huge in terms of real-world length units.
> Sounds like this should be reported as a bug if it does not already have
> a ticket and post the bug number here so people can add themselves to
> the cc list to track it.
I will just have a look at the bugtracker if there is something like this
already reported.
Sven
"If you don't make lower-resolution mapping data publicly
available, there will be people with their cars and GPS
devices, driving around with their laptops" (Tim Berners-Lee)
/me is giggls at ircnet, http://sven.gegg.us/ on the Web
